Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - what does the square, and the triangle mean on a cloyes gear set
Old 06-17-2004, 06:42 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Originally posted by 87442lover
Actually retarding the cam 4 degs does lower your torque by a few points, but the higher end HP gained is sometimes well worth it on cams with a duration in between the 240-265 range.
To the best of my knowledge, advancing the cam timing 4 degrees will lower when the torque curve begins by about 200 RPM. This will yield more bottom end.
Conversely, retarding the cam timing 4 degrees will raise when the torque curve begins by about 200 RPM. This will yield more top end.
