-   -   what does the square, and the triangle mean on a cloyes gear set (http://www.hotrodders.com/forum/what-does-square-triangle-mean-cloyes-gear-set-41735.html)
bullheimer 06-16-2004 11:54 PM
my crank gear is on the square. if that's for low end, i like it, if it's for advanced i will have to take it off. i dont want to . all i know is the circle is for straight up and it aint on the circle.
Frisco 06-17-2004 04:06 AM
Re: what does the square, and the triangle mean on a cloyes gear set
Here's a link for you.
Timing Chain Install
As you can see, setting the crank sprocket on the square RETARDS the timing. This will give you LESS bottom end and more top end. NOT what you want.
87442lover 06-17-2004 05:25 AM
Actually retarding the cam 4 degs does lower your torque by a few points, but the higher end HP gained is sometimes well worth it on cams with a duration in between the 240-265 range.
Frisco 06-17-2004 06:42 AM
To the best of my knowledge, advancing the cam timing 4 degrees will lower when the torque curve begins by about 200 RPM. This will yield more bottom end.
Conversely, retarding the cam timing 4 degrees will raise when the torque curve begins by about 200 RPM. This will yield more top end.
machine shop tom 06-17-2004 08:03 AM
Square--Moe
Round--Larry
Triangle--Curly
Advancing the cam increases low-end torque while compromosing high end power. Retardng the cam does the opposite.
tom
