What is this drain plug ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2012, 01:44 PM
64Joker's Avatar
64Joker
Is this a water drain plug? See attached pic.
Engine: 327 cui
Camera Shot: Picture was shot from underneath car on driver side.
That dirty chrome object under the plug is the oil pan!
Name:	drain plug 1.jpg
Old 08-15-2012, 02:05 PM
327NUT's Avatar
Yes it's a drain plug, should have one on either side. Usually when you pull one out of an old engine the little hole is full of crud and you have to take a screw driver or large nail and punch through the mess. Some guys will remove it and screw in a petcock if they plan on draining their fluid very often (???).
air compressor drain plug tcoop Garage - Tools 20 12-04-2009 07:42 PM
7/8-16 Oil Drain plug? Simplicity Engine 3 08-12-2009 06:55 AM
9" drain plug Javelin69 Transmission - Rearend 2 10-03-2007 08:00 PM
Aftermarket Drain Plug MI2600 Transmission - Rearend 12 08-15-2006 01:07 PM
coolant block drain plug jwash56 Hotrodding Basics 9 04-25-2004 03:33 PM
