What effects does low rpm's have on air fuel mixture? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2013, 12:02 PM
(preface: 355sbc, 232@.50 480lift cam, decent heads, rpm air gap, holley 650 dp, t5 manual)
I put a wideband gauge in my Camaro and I've been having fun fine tuning this carb with it. Got it dialed pretty good so far, but wondering about something. It seems to stay lean until about 2k, 2.5k rpms. For instance, if I'm on the highway at 35mph in 4th gear and floor it, it shoots to about 15:1 and slowly lowers as the rpms raise. By about 2k-2.5k it drops to it's normal "way too rich" wot mixture of about 11:1.
I realize that an afr between 10 and 11 at wot is very rich, and I'm gonna tackle that next, but first I wanted to know if maybe this "lean until 2k rpms" thing is an indication of bad timing. I'm running about 21 initial and 36 all in with no vacuum atm. 1 medium 1 light spring.
Any ideas?
Old 03-30-2013, 12:08 PM
vinniekq2's Avatar
11.9-12.2:1 is good for racing.maybe aim for 13:1 for street.
do you have remove able air bleeds?
Old 03-30-2013, 12:18 PM
Yes I do. Why?
What do you mean by this? That I should aim for 13 at wot because I DD it? If I idle at a nice happy mid-14, shouldn't 11.9-12.2 be fine at wot?
Old 03-30-2013, 12:20 PM
I've never used a double pumper, but could it be a bad power valve?
ssmonty
Old 03-30-2013, 12:25 PM
ssmonty
I wouldn't think so. I actually just yesterday switched from a 4.5 power valve to a 6.5(got about 8 intake vacuum at idle). It REALLY helped it smooth out. With the 4.5 it would shoot VERY lean at part throttle acceleration. With the 6.5 it's extremely consistent and smooth no matter how much pedal I give it.
Old 03-30-2013, 12:32 PM
vinniekq2's Avatar
have you already advanced the accellerator cam? and or changed discharge nozzles?
Old 03-30-2013, 02:39 PM
Banned
Try a smaller air bleed, you'll need to lower your jet size a little after that too.
Old 03-31-2013, 12:41 PM
75gmck25's Avatar
My SBC 350 with a rebuilt Quadrajet and a mild cam runs about 13.5 AFR in normal driving, and drops to about 12 at full throttle. Its probably not set up for optimum performance, but street driveability is great. It starts and runs well, and feels strong right off the line. However, my engine is limited by stock heads and iron exhaust manifolds, so I haven't tried getting more out of the carb tuning.
Bruce
air/fuel mixture strokin Engine 2 12-05-2011 05:01 PM
air/fuel mixture and air fuel gauges questions tomcraft Hotrodding Basics 10 08-20-2009 11:40 AM
Fuel mixture and air temperature SAATR Engine 1 04-01-2005 08:01 PM
Air/Fuel mixture and performance orian Engine 13 01-16-2005 09:24 AM
air/fuel mixture???? FenderGitars Engine 6 08-28-2004 07:59 PM
