What else do I need? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2004, 05:47 PM
Hey Guys,
Assuming I've just bought a 1970s smallblock Chevy longblock, what else do I need to buy before I can fire up the engine?
Intake manifold & carb
distributor
alternator
What else?????
Lobo in West Virginia
Old 10-13-2004, 05:53 PM
gpeak's Avatar
Plugs, wires, battery, gas, lol.....etc.etc.
Old 10-13-2004, 09:26 PM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
If the engine has a new cam be sure to break it in properly, If you do a search in the engine forum for cam break in You'll find the whole process.
Old 10-14-2004, 06:37 AM
Come on Guys,
I'm here because you folks are supposed to know engines!
Harmonic balancer
Fly wheel
Do these come with a longblock?
Old 10-14-2004, 08:16 AM
Odium's Avatar
ok, assuming the following is included in the long block;
block
crank
main bearings
rods
rod bearings
pistons and rings
timing chain
cam
cam bearings
heads
lifters
pushrods
valves
springs
retainers, shims, etc.
rockers
you're going to need;
oil pump+hardware
oil pan
intake manifold
carb
air cleaner
carb linkage
timing cover
balancer
pullies
alternator+bracket
power steering? pump+bracket
water pump
plugs
wires
distributor
valve covers
full gaskets+fasteners
belts
Did I miss anything?
Old 10-14-2004, 06:53 PM
Odium,
Fuel pump came to mind today. Thanks for your help. I'm trying to figure out how much this engine's going to cost me.
Old 10-15-2004, 07:32 AM
Odium's Avatar
Yea, fuel pump. You also have to take the trans into account, propper cooling for the power your going to make, correct fuel delivery, engine mounts, etc. And a starter.
Old 10-15-2004, 07:07 PM
gpeak's Avatar
Well, where i'm from, you buy a used long block- everything comes with it. Unless you are buying a long block from a manufacturer, why wouldn't these things be on there? Including the balancer, flywheel, water pump, and all the covers. Guess you should be more specific as to the term "long block".
Old 10-15-2004, 07:12 PM
poncho62's Avatar
Wiki Edits: 5
If you are putting this in a certain car, you should have most of the parts already........................
Old 10-16-2004, 07:24 AM
Hey Guys,
The "longblock" comes from a company that specializes in re-manufacturing engines.
http://www.rebuilt-auto-engines.com/...51104093868.7b
This engine will be going into a '26 Lakes Modified Roadster designed around the Chevy smallblock.
http://www.zippermotors.com/page17.html
Old 10-16-2004, 07:25 AM
Tazz
ask the people your buying your long block from what comes with it.... they just might be able to tell you what else you need...or buy a crate motor complete.
Tazz
Rat Rods Rule!
Old 10-16-2004, 07:34 AM
Hey Tazz,
The engine builder will build to your specs and do complete engines. As with a lot of builders, $$$$ is my limiting factor. In fact Zipper Motors will build the car turnkey for a price. My wife and I are putting most of our extra income into the mortgage right now, so the house will be paid off when she's ready to retire in a couple of years--24 payments left. "My Car" gets the left overs and money from second jobs.
Old 10-16-2004, 01:19 PM
Tazz
Look for a donor car/truck with a a good drive train and use it until such time you decide to disassemble it to build your project. Or watch the papers..do you have access to: www.cruisintimes.org/
and see if you can hook up with something you can use.
Tazz
Rat Rods Rule!
