First to answer you, "your being penny-wise and dollar stupid"
Yes wax and grease removers are to a degree simple in formulation however even though there are 2-4 different solvents in the product the wrong formulation can be disaster! Give you an example: PPG makes a 330 (a normal wax and grease remover) and a 440 harsher and slower, the 440 is for prewash before sanding or big rigs but I have seen a number of paint jobs done over because someone used it as a finale clean and it never really dried. People use windex, alcohol and water, ammonia and water and vinegar and water. Its a risk that can be costly. |
The only one I don't have issues with is a 50/50 mix of alcohol and water. The environment I work in has a number of high speed laser scanners. These have some very precise rotating mirror assemblies in them that have to be cleaned regularly. They are 'front surface' mirrors and can not actually be touched without causing some damage. The manufacturer specifies the alcohol/water mix as the only acceptable cleaning fluid. The mirrors dry clean and spotless. I would believe anything else might leave a residue but that mix does not.
The hardware store Mineral spirits is not pure, and can actually contain a cocktail of other undesirable chemicals. Take everyones advice and stick with the products designed to work with your paint...you will be better off in the long run. Use the cheap stuff to clean up with.
Vince |
That 20 bucks may seem like a lot compared to the five dollar can at the McHome store, but it is a FAR SIDE less than the $500.00-$1,000.00 you will be spending on the rest of the paint materials!
I say spend the $20.00 on the surface cleaner paint manufactures says to use. >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> “Basics of Basics” Surface cleaners By Brian Martin They are commonly called “Wax and Grease Removers” but many manufactures have changed the name to “Surface Cleaners” or similar names. I think the biggest reason is because the name “Wax and grease remover” implies that they will actually clean all of the wax and grease off the surface. The other reason for a name change is the simple point that wax and grease are only a few of the contaminants that you battle against while painting. The basic idea behind these cleaners is simple, they are designed to lift the contaminant up off the surface long enough for you to wipe it away. The surface MUST stay wet and HOLD those contaminants up in the cleaner for you to wipe off with a clean/dry rag. That is mistake most make, they let it dry and the contaminant ends up laying right back on the surface. First of all let’s clear up a few things; Lacquer thinner, acetone, MEK, and enamel or urethane reducers are NOT surface cleaners. Lacquer thinner evaporates too fast and doesn’t give you time to wipe it off wet. It is also much to strong a solvent for most cleaning and can get under the edges of sand thrus or soften substrates. Enamel and urethane reducers often have resins and other components in them that are designed to be added to the product they were INTENDED to be used with. To put it in a nutshell, buy and use the products recommended by the manufacture of the paint SYSTEM you are using. A gallon of the proper surface cleaner runs about twenty or twenty five dollars it is money well spent. The gallon will last you through many projects, a few cars even. The pint of paint or clear to do one small redo will cost more than that. I checked on our paint dept. at work to see how much surface cleaner they go through. We do between 100 and 150 cars a month and purchase three to five gallons of surface cleaner. We purchase about $12,000 a month in paint materials and only about one hundred bucks of that is surface cleaner. So that being said, at that rate a gallon should last a home hobbyist a lifetime, so buy the right product for the job. One reason we use so little is how we use it. Here in the San Francisco bay area with strict VOC rules we are not allowed to pour the surface cleaner out onto a rag. We have to spray it out of a spray bottle. Like most things we are forced to do, we resist. But it has turned out to be a great way to use this product. You should give it a try, it works real well. You spray the panel and then wipe it off. I like to have lots of clean rags when I am doing paint work. Clean rags are one of the most important item you can have in a shop. In the last few years this has gotten much easier to do. I remember having a can of paint covered rags in the corner, thinking I could wash them. I would wash them and they would be clean but the dried paint on them would be hard and make the rags unusable. Then of course you don’t want to wash them in your home washer anyway, unless you want your wife’s bra to smell like enamel reducer. Now a days the disposable rag is king. You can get a box of “rags” for a pretty fair price and just throw them way when done. You always have nice clean rags. They are not “just” paper towels, so don’t think that the “Mr. Cleanup” paper towels you get at the supermarket are going to do the job. Go to your paint store and get the real thing. There are many different kinds, from cheap wipes similar to your kitchen “paper towels” to lint free towels for final wiping. TORX products are available at NAPA auto parts and is one source for these towels. Again, yes they cost more money than washing rags or your wife’s “Mr. Cleanup” paper towels but what kind of money are you spending on your paint products? So let’s go over exactly how you use it. As mentioned earlier, you need to keep it wet prior to wiping it off. The best way to do this is keeping your cleaning area down to a manageable size. I usually wipe no more than a half a panel at a time. About six square feet is all you can do without problems of it drying to fast, and even then you have to keep moving pretty fast. You just don’t want it to dry, if you do, you have wasted your time. You haven’t done what you intended to do, at all. It was not even close, you wasted your time. When should you wipe the surface? Well first of all, BEFORE you sand. If you don’t wipe the surface before you sand you will not sand off the contaminants, you will sand them INTO the surface. So a good cleaning before sanding is recommended. If the surface is really dirty, clean it a few times changing to clean rags every time. Remember, you want to wipe off the contaminants, so if you use the same rags on the subsequent wipes you can leave the contaminants you wiped off on the first wipe! Wiping before applying primer or paint of course is also recommended. Broom and/or blow off the sanding dust (I have bench brooms for wood working that are fine bristled and work great). Be sure to use the proper cleaner and wipe it dry really well. Then be sure that any remainder has flashed off (evaporated) before applying your primer or paint. You don’t want any of the cleaner to be trapped under your primer or paint! Have a few rags ready to go folded in fourths. Put the rag over the opening on the can of surface cleaner and give the can a “slosh” getting the rag wet, not too wet but wet. You don’t need to have it dripping all over the floor, but it should be good and wet. Get in the habit of wiping things down like you are painting it. Use a back and forth pattern with an over lap being sure to wet EVERY square inch. The entire area should be shiny wet, then switch to a clean dry rag and wipe it dry using the same “get every inch” procedure. If you feel it dried before you could get it off, repeat the cleaning. As a painter I worked under many years ago would make me repeat like a private in boot camp “YOU CAN NEVER GET A CAR TOO CLEAN, SIR” Because the term “wax and grease remover” is thrown around so much little is said about the how different they can be. Until I had became a paint rep I didn’t even know there were different kinds. After painting for twenty years I had always just grabbed the “wax and grease remover” without a thought as to what I was using it on. When I bought a cleaner and found it worked different I just attributed it to the brand and not the fact that it was just not the type of cleaner I had been using. Just like solvents you add to your paint products there are different “temps” cleaners. Not that they are to be used in different temp shops but that they flash faster or slower than another. This is important in that you don’t need a super slow flashing cleaner on your final wipe. Nor do you need a super fast one when you are doing your first wipe down of a greasy car prior to sanding. There are also different “strengths” of cleaners. Some are designed for cleaning soft substrates like lacquer while others are much more harsh for cleaning enamel substrates. Most all of them “can” be used at most times but, there are some that are better than others for particular circumstances. There are four common groups. I don’t have every cleaner listed here but this will give you a good idea at what is available. 1. A very slow evaporating cleaner. It is also very weak, and actually may only be mineral spirits or mostly mineral spirits. This does NOT mean you can go to the hardware store and buy their mineral spirits, for goodness sakes just but the high grade product from the paint manufacture. This is the type of cleaner is the most common found in the shop. It is a good cleaner because it is weak and will not attack any soft substrates like lacquer, uncured enamels, etc. But it will not clean a lot of strong contaminants like vinyl treatments. When you have a reason to believe there is a particularly bad contaminant you may need to go to a stronger cleaner. It is very slow evaporating so you have to be sure it is fully evaporated after wiping before you apply any paint product over it. Specifically those nooks and crannies, be sure it is good and gone before you apply any paint product. It gives you lots of time to wipe it off because it evaporates so slow. Examples are: Sherwin Williams R1K213, Martin Senour 6387, PPG DX330, DuPont 3939S, BASF 901. 2. This cleaner is fast and strong. It is commonly recommended as a “pre-cleaner” before sanding. It will attack some soft substrates like lacquer and uncured enamel but if you are using it before sanding you can correct that. It will clean the stronger contaminants like tar and unseen ones like silicone vinyl protectants. Examples are: Sherwin Williams R7K156, Martin Senour 6383, PPG DX440, DuPont 3919S, BASF 900. 3. This cleaner is a weak solvent with fast evaporation and is usually used just prior to painting, while the car is in the booth. It is very fast evaporating and is necessary in the production shop where you don’t have the time to wait for a cleaner like #1 to evaporate. It is perfect for this use, just getting those finger prints and dust residue off. Examples are: Sherwin Williams R7K158, Martin Senour 6384, PPG DX30, DuPont 3901S, BASF 901. 4. Because of VOC rules a waterborne solvent cleaner was developed. It is not needed in most of the country but it has been found to have an interesting use there. Because it has water in it (water and alcohol molecules share a common atom so they are a “link” between the water and enamel based solvents) it actually helps with static electricity. Washing the car with water is the best, but that can’t always be done. It is also the recommended surface cleaner for plastic parts with many paint systems. Examples are: Sherwin Williams W4K157, Martin Senour 6388, PPG DX380, DuPont 3909 or 3949, BASF 905. If you find that you have been using the “wrong” cleaner, don’t sweat it, it is not THAT critical. As I said, there are cleaners that work better than others in certain circumstances but few would be “wrong”. I know of one particular mistake I made for many years. I was using one from the number 1 example. I used it all the time as I still do. The problem was I was using it wrong. Back in the days of lacquer primers and paint I had a few problems that I just couldn’t figure out, till years later that is. I would see a lacquer paint job I did a year or so later and there would be water spots on it, coming from under or within the paint. It looked just like you would have when you dry a car in the sun and the water would dry in the patterns that the wet towel left. I always knew it was the surface cleaner but just couldn’t figure out why it would happen. I now know that the cleaner was just too slow evaporating and some stayed on the surface to be buried under the paint. The lacquer primer soaked it up and held it. If I had waited a little while longer before painting or used one from the number 3 example I wouldn’t have had a problem. Hopefully this info will help you choose the best cleaner for the job. But most off all, I hope it puts to rest all the “old husbands tales” of using thinner or enamel reducers as cleaners. Addition: Lacquer thinner, acetone or others can be used to preclean a greasy frame or something of course. These recommendations are for prior to using paint/primer products. Last edited by MARTINSR; 11-04-2004 at 08:14 AM. |
i totally agree with everyone above. a long time ago i asked the same question because i used to use the stuff from dupont (i forget the #). on the side of the can it said mineral spirits and touline which made me wonder the same thing. i still always use wax and grease remover except for when i need to wipe down over airbrushed artwork before clearing. in which case i will use mineral spirits and this is for one reason. mineral spirits is about the most gentle solvent i have found and airbrush work is very delicate. most regular wax and grease removers will wipe it off while mineral spirits has no effect, however, i make sure the surface is completely dry before clearing. i will sometimes even take a heat gun over the surface to warm it just to make sure. i have never had any ill effects from using the $4 stuff but like i said i am very careful and never use it to completely wipe down a whole panel or a car before painting.
Use Old Motor Oil
You may as well wipe old motor oil on your car as oppossed to mineral spirits.
Wax and grease remover is highly refined and common mineral spirits is about refined as crude oil. The worst thing you can do is try and substitute with a lessor product during preping. One guy was almost right on alcohol and water. I use about 2 ounces of alcohol with fast reducer and spray this as my final wash with my spray gun. This will also release any static electricity from the surface. |
If you put your wax and grease remover in a spray bottle you
can wipe as you spray, makes it much easier and effective. |
Yea, I know.
I stole that idea from Bondoqueen, big improvement over what he use to do. He would spit on the car and use paper towels. |
Good timing this thread came back to life.
We just got done breaking down all the top grades of wax and grease removers to update our formula. We only checked the top grades (high dollar) no omni no nason etc. I cannot speak for the cheap grade as did not check and did not really care. First let me assure you none of the MSDS sheets or labels are exact and second let me assure you none of them had mineral spirits in them. |
---------------------------------------------------------------------------Heres a little more.-----
Dirt, specks, cracks, little boogers in the paint. This is just one little part of paint prep that might help you out. Theres a lot to it, and there are experts on here that have forgot more then I will ever know, but I showed an old bodyman this and he says it really helped him out. This is my little segment to the ballgame. I worked in a nuclear power plant for quite a few years, and this is how it works. Contamination can't be detected by the human eye, that's why they have meters to find it. Take the dust on top of your television, if you wipe it you will see some dirt on the rag, well in a power plant you have a few places that have contamination, maybe on top of a pipe or valve that has a small leak, you might not even see it but, if you wipe that little bit of dust off from it and check it with a meter you might find contamination, which is radiation in a unwanted area, something like that. These areas are in a controlled area that the general public cannot get into, and the power plant monitors and cleans them up when they show up. When you clean something contaminated you decon it, now I'm getting to the point if you're still with me. When you clean, let's say a surface two feet long by a foot tall, you can sometimes scrub it several times until it's squeaky clean, then take a clean rag and take one wipe down the side, put a meter on it and you still might show contamination. So you're looking at this and it's spotless yet the meter shows its still got something on it. If you wipe one time then turn the rag over to a clean part of it and wipe one time the other way, you might have to do this a couple of times, but experience at wiping one way, rather then using the same part of the rag to go the other direction is what works to get rid of contamination you can't see. So, put a little acryliclean on your fender, take a clean rag and wipe once down the side, turn the rag over so its clean and wipe again, don't go back and forth without turning the rag over. If this process will clean stuff you can't see with the human eye, then its a pretty sure bet you have it clean. Also you don't have to put a lot of pressure on the surface when you wipe it. Hers a tip on cleaning cast iron parts on your chassis using acryliclean. Spray the part until its moist looking, then take the air hose and blow from one end to the other, like rinsing a wall, one end to the other, not back and forth, usually at least a couple of times. I use napa 7222 primer and napa 7250 iron block/cast. Just spray them lightly and that way the cast iron will look like cast iron instead of the woodwork in an apartment I used to rent that had twelve coats of paint on the woodwork. Number 9 wire at a building supply makes excellent hangers for your detail work. When painting hard to get at areas like inside frame rails, spring pockets, use a siphon type gun like the old standard binks #7, otherwise the hvlp cup will get in the way, I have a bright flash light in one hand when I spray those hidden areas. I was a little long winded on the radiation/contamination, but anybody that ever tried to explain it usually wound up writing several volumes on it. You might have heard some of this before, but I want to try to contribute to a site that I have taken so much from. Rob. __________________ "There are questions to be answered, and answers to be questioned" Chassis, Body Jig, Trunk Pan Pics. http://webpages.charter.net/2manitowoc Rob |
Barry, S-W R1K213 states (as I remember) "100%" mineral spirits, are you saying it has NONE? And, I know this is a stupid question but what guidelines do you go by? I mean, could a company call something "mineral spirits" that under some "Chemical club of America" guidelines it is "mineral spirits" but by your "opinion" it isn't? I am so far out of the understanding of the chemistry I don't get it. Brian |
