What is this engine ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-13-2007, 12:18 PM
Last journal entry: 1952 Chevy Street Rod Truck Build
I know I saw a guide to ID a Chevy engine on here but can't locate it when I need.The # is 3970014 and I bought it for it being a 350 ci.
Old 07-13-2007, 12:22 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
http://www.google.com/search?hl=en&q...=Google+Search
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
http://www.thedirtforum.com/castings.htm
Old 07-13-2007, 12:33 PM
nitro_baller4692's Avatar
floppers forever
it is a 350 but could be either a 2 or 4 bolt main.year 1970-1976
Old 07-13-2007, 12:34 PM
re: what is this engine
According to www.mortec.com its a:
3970014....350...70-76...2 or 4 bolt
Old 07-13-2007, 12:40 PM
F&J F&J is offline
Yes, but I think one of the charts also shows 68-69 hi-perf, as well as the later uses.
Old 07-13-2007, 01:32 PM
Jmark's Avatar
It "could" be a high performance engine but the BLOCK is the same. The piston/intake/head/carb selection is what makes the HP version of the engine, not the block itself.
Mark
Old 07-13-2007, 03:16 PM
runn141's Avatar
SB S10
most 350's ive seen with that casting# had a steel crank
Old 07-13-2007, 07:06 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
I can't really say much else that anybody hasn't already said. But the 350 in my Blazer has this casting number, it's a two bolt main and has a cast crank.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
1973 Chevelle Malibu Engine Rebuild (pics 56k no) Malibu73 Hotrodders' Lounge 39 11-04-2008 12:37 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Engine....whats it worth? chevyusa1 Engine 6 06-11-2007 06:43 PM
Why high RPM's on the oval tack? steveyb4342 Engine 25 05-23-2007 07:50 AM
