-   -   what engine do i have (http://www.hotrodders.com/forum/what-engine-do-i-have-180987.html)
Jimmy Dean King 07-13-2010 12:09 AM
I have a 1967 SBC eather 302 327 350 crank and heads are 302 block casting is 3858174 suffix code is F0411YW can any one help me with this thanks :thumbup:
American Muscle 07-13-2010 12:21 AM
1966-327 ci long block-185 hp
Check out this link
http://www.nastyz28.com/sbchevy/sblock.php
Jimmy Dean King 07-13-2010 12:34 AM
thank you but i have checked that site and several others all say different i really want to kno what the yw in the suffix code means i got the block heads and crank from a kid who siad it came out of his dads 67 camaro after it was t boned in 73 heads and crank are 302 date code comes up as 67
va4cqd 07-13-2010 06:27 AM
YW 66 327 Truck 185hp Base Manual 2-Brl
Jimmy Dean King 07-13-2010 08:35 AM
thank you if you dont mind can i ask where you found that i've been looking for months online and cant find it thanks james
DoubleVision 07-13-2010 10:43 AM
YW 66 327 Truck 185 Base Manual 2-Brl
This was found at:
http://www.chevymania.com/
cobalt327 07-13-2010 11:43 AM
3858174: '64-'67 327cid car & truck 2-bolt
YW: '66 327cid Truck 185HP Base Manual Trans 2-Brl
So, this amounts to a low compression (for then) base small journal 327.
Unless the heads originally had 2.02" x 1.60" valves and screw in studs/guide plates, they're not from a 302. Head castings like the 461, 462, 291, 186, etc. were used in 1.94" x 1.50" valve size (w/o plates and screw in studs) as well as 2.02 x 1.60" valve sizes...
va4cqd 07-13-2010 03:05 PM
http://www.chevymania.com/partsid/su...fm?block=Small
