what engine to put in a 71 nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2006, 07:44 PM
hey fellas, just wonderin what engine i should put in this beast. i was leaning toward a 427 small block, but there is no substitution for a big blocks raw power. i can get a 496 short block for 3950 bucks, and a 427 short block for 3500. what would you guys go with? p.s. this will be an aluminum headed engine with either a victor or rpm air-gap intake.
Old 03-15-2006, 08:23 PM
copndoc3's Avatar
Retired Super Trooper
Last journal entry: The Uncommon Street Rod - Photoshoot
If it's raw big block power your after, I'd put a 500 cid Cadillac mill in it. You'll have torque out the ying-yang and it will idle like a ***** cat. The perfect sleeper. And it's not much heavier than a small block.
Old 03-15-2006, 10:29 PM
firestone's Avatar
http://teamrfc.gospelcom.net
I would go with a 496. What heads are you going with?
Here is a combonation to think about:
http://airflowresearch.com/articles/article52/A-P1.htm
Adam
Old 03-15-2006, 10:36 PM
rick458's Avatar
Wookie
I Just like 427s
what did the car come with?
Rich
77 Impala
74 260Z (a Work in SLOW Progress)
69 Big Block Chevelle (long gone)
Semper Fi My Brothers
Old 03-19-2006, 02:23 PM
origonal engine
it originally came with a 250 straight six. i'm also considering a 383 stroker. the cadillac engine is great, but i want to keep this engine chevy oriented. no real reason, i just like it better that way. i don't know the gear ratio other than it is a 6 cyl rear end. i'm taking plenty of time to ensure that this car is all stock............................................. .....................except under the hood
Old 03-19-2006, 02:31 PM
steve t's Avatar
ex biker, now hotrodder
you may have to update that 6 cyl rearend if you go a lot of h p
Old 03-20-2006, 06:02 PM
rear end
i will. it will more than likely be around 450hp/460tq
Old 03-20-2006, 06:10 PM
Wiki Edits: 31
the original rear end should be a 4.11, open rear end, might be a little weak.
Old 03-20-2006, 11:34 PM
If the rear end is original it should be an 8.2" 10-bolt with 3.08 or maybe 2.73 gears. Not the strongest rear end, but not really weak, either. Some 350 cars got them. Slicks & a big-block would probably kill it, though.
Old 03-24-2006, 07:50 PM
rearend
if it is weak, what would be a good gear for 6500 rpm, and positive traction? i do not want to tub this car, id rather just have a 60 or 50 on the back. i can get a complete 383 out of comp. products for 3000 "long block" is this a good engine, or should i go with something else. ive also saw a 383 reman recon. is this a good engine or is this junk. i'm new to the hot rod game and don't want to make a huge mistake. i really want to do it once and be done with it. all of you pros out there please,please,please help me.
Old 03-24-2006, 09:25 PM
Paul Suburban Murray's Avatar
Blazer Paul
454 Crank in SBC
I read in a back issue of Hot Rod Magazine where on a bet a gentleman had a SBC 350 ground out for a 454 BBC Crank to be installed, this created a higher stroke, BBC power and torque, SBC miledge, and low 1/4 mile times. All in all an interesting idea. However I must say I would much rather a SBC 350 4bolt. You see SBC's runs cooler in general then BBC's, and SBC's are smaller therefore you have a little more room under the hood.
Paul
Old 03-24-2006, 09:55 PM
re: what engine to put in a 71 nova
For what it's worth, I just dropped a factory GM Performance 350 long block in my '70 Cutlass...dressed it out with racing components.....830 CFM carb and the power is awesome. I've heard the GM performance 383 Stroker will make you smile all day. The 350 cost me $1900 from a friend who owns a dealership. I believe the 383 sells for around $2800. For everyone I had talked to, the GM performance long blocks are very reliable.
Hope it helps,
Dane
Old 03-28-2006, 11:11 AM
thanks
you guys are great, everyone who has helped me. is a 383 a good engine for a nova that will never be put on the track? or should i go with a built 350?
Old 03-28-2006, 12:22 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Either one would work well, I personally prefer 383's for the low end torque. '71-'77 Novas and their GM counterparts used the 8.5" 10 bolt. These are plentiful and with a little work as strong as most 12 bolts. Unless you tub it ( don't blame you for not wanting to ) you'll have to do some massaging to get any tire to speak of under it but if you get the suspension working right it will hook pretty well on a 9" slick. Forget about 60's with any height to them for the street unless you want to jack it up 70's style.
I'd love to have another Nova one of these days, I kick myself for selling my '70. It was a Fathom Green SS396/350HP/4 speed with black bucket seat interior. Guy I sold it to in the early 80's cut it up for a Super Gas bracket car......
Old 03-28-2006, 01:25 PM
firestone's Avatar
I would consider either of the motors below. The 383 with a fairly mild hyd flat tappet cam will make minimum 450 hp and 450 tq.
below is from http://www.revolutionaryperformance.com/
Street/Strip Stroker AFR Upgrade SBC 383 4 bolt main block, Eagle cast steel 3.75" crank, Eagle SIR 5.7" rods, KB Performance or Sealed Power hypereutectic 9.6:1 pistons, Sealed Power rings, solid or hydraulic flat tappet cam, double roller timing set, new balancer and flexplate, pushrods, Air Flow Research 195cc heads, HP springs, locks, and seals, aluminum race series 1.6 rocker arms standard $4,149.
Here are a couple of motors to compare to
http://airflowresearch.com/dyno/chevy_dyno.htm
I would recommend the 496 though. I am currently in the process of building a 10:1 oval port headed 496. My heads are 049's with a full port job and my cam is 248 245 @.050 ~.680 lift solid roller. That may be a little agressive for what you are after, but comparing this to similar combonations, it should be around 600 hp and 600 tq. I also know of a 468 with 9.5:1 compression and cleaned up 049's along with a 242 @.050 hyd roller cam that made 560 hp and 560 tq on an engine dyno.
Adam
350 engine swap 71 pickup Batmat Engine 4 01-02-2006 01:11 PM
Put back together engine but it runs like ****. 61ChevyTruck Engine 2 01-25-2005 11:53 AM
white smoke and engine dropping revs when put into gear andybird Engine 2 06-24-2003 01:01 AM
I want to put 7 grand into my engine neil madsen Engine 35 02-28-2003 07:07 PM
Need Wiring Diagram for 71 Nova sonicse Electrical 5 01-24-2003 01:24 PM
