-   -   What engine should I build? (http://www.hotrodders.com/forum/what-engine-should-i-build-203403.html)
stallion0606 08-08-2011 07:04 PM
i have a 350 block, 350 heads, 400 crank, 350 pistons, and 305 h rods. what need to be done to build a proper 383 stroker
Scandinavian 08-12-2011 06:47 AM
messurements on the parts would help!
bigdog7373 08-12-2011 07:45 AM
Get a 383 crank, rods, and pistons.
swvalcon 08-12-2011 09:02 AM
Grinding a 400 crank to 383 will cost as much or more than a aftermarket. 350 pistons wont work wrong pin hight. best to buy a ready made kit.
bigdog7373 08-12-2011 11:22 AM
Heres a good deal on a rotating assembly for a street engine. http://www.northernautoparts.com/Pro...tModelId=14966
Just have to get it balanced.
F-BIRD'88 08-12-2011 04:31 PM
Get a set of 400 SBC 5.565" connecting rods. The mains on the crank need to be turned down to the 350 crank size. The 400 crank will need to be re-balanced.
The 350 block will need some hand clearance grinding on the bottoms of the cylinders and the oil pan rail for crank/rod clearance.
lil red s10 08-12-2011 07:08 PM
i thought a 400 crank in a 350 + 30 over made it a 383??? and that the block had to be machined??
there's a lot i dont know... so just asking questions.
larryf 08-12-2011 07:40 PM
Competition Products in Oshkosh Wis. has excellantprices,sharp phone techs,and free shipping.Lot cheaper than reinventing the wheel,Google them.GEt us the numbers on the block and heads.Just my thoughts.LARRY :) All you need to start is a rotating assembly
stallion0606 01-13-2012 07:49 PM
i do have a stock 400sbc (as far as i know) and a stock 350 sbc complete. and a set of 305 h rods and pistons stock. i would appreciate some ideas. going in a 1985 pontiac traans am
327NUT 01-13-2012 08:44 PM
..........and 5 months later he returns ?????? If you have a complete 400 sbc then just build it into a 406, why spend a lot of money to get a lesser engine? A 406 will chit on a 383 with the same parts.
stallion0606 01-18-2012 06:23 PM
what do i need to do or get for that 400 to a 406
68NovaSS 01-18-2012 06:33 PM
Have it bored +.030. You'll need .030 oversize pistons.
68NovaSS 01-18-2012 10:15 PM
Yes, but it only means a crank with a 400's stroke of 3.75". You can use an OEM 400 crank but need to resize the journals to 350 specs.
stallion0606 01-20-2012 10:50 PM
is there any more suggestions on that 406 or how to keep that engine cool that those engines are known for. would getting it internally balanced do any good or should i leave that part alone. anything helps thanks
F-BIRD'88 01-21-2012 05:15 AM
my 400sbc has never overheated. Its a myth.
