What engine should I build? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2011, 07:04 PM
i have a 350 block, 350 heads, 400 crank, 350 pistons, and 305 h rods. what need to be done to build a proper 383 stroker
Old 08-12-2011, 06:47 AM
Scandinavian's Avatar
http://www.backfalt.fi/indexse
Last journal entry: Torque Converter
messurements on the parts would help!
Old 08-12-2011, 07:45 AM
bigdog7373's Avatar
Of course it's fast
Get a 383 crank, rods, and pistons.
Old 08-12-2011, 09:02 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Grinding a 400 crank to 383 will cost as much or more than a aftermarket. 350 pistons wont work wrong pin hight. best to buy a ready made kit.
Old 08-12-2011, 11:22 AM
bigdog7373's Avatar
Of course it's fast
Heres a good deal on a rotating assembly for a street engine. http://www.northernautoparts.com/Pro...tModelId=14966
Just have to get it balanced.
Old 08-12-2011, 07:08 PM
Last journal entry: It starts...
i thought a 400 crank in a 350 + 30 over made it a 383??? and that the block had to be machined??
there's a lot i dont know... so just asking questions.
Old 08-12-2011, 07:40 PM
Competition Products in Oshkosh Wis. has excellantprices,sharp phone techs,and free shipping.Lot cheaper than reinventing the wheel,Google them.GEt us the numbers on the block and heads.Just my thoughts.LARRY All you need to start is a rotating assembly
Old 01-13-2012, 07:49 PM
i do have a stock 400sbc (as far as i know) and a stock 350 sbc complete. and a set of 305 h rods and pistons stock. i would appreciate some ideas. going in a 1985 pontiac traans am
Old 01-13-2012, 08:44 PM
327NUT's Avatar
..........and 5 months later he returns ?????? If you have a complete 400 sbc then just build it into a 406, why spend a lot of money to get a lesser engine? A 406 will chit on a 383 with the same parts.
Old 01-18-2012, 06:23 PM
what do i need to do or get for that 400 to a 406
Old 01-18-2012, 06:33 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Have it bored +.030. You'll need .030 oversize pistons.
Semper Fi
Old 01-18-2012, 10:15 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Yes, but it only means a crank with a 400's stroke of 3.75". You can use an OEM 400 crank but need to resize the journals to 350 specs.
Semper Fi
Old 01-20-2012, 10:50 PM
is there any more suggestions on that 406 or how to keep that engine cool that those engines are known for. would getting it internally balanced do any good or should i leave that part alone. anything helps thanks
Old 01-21-2012, 05:29 AM
TroyBoy's Avatar
Psychomotors
^x2 . Before we discuss int or ext balancing, what are your plans for the engine? What heads, intake, cam, etc. We are just trying to not have you spend unnessasary money.
Old 01-21-2012, 11:03 AM
adantessr's Avatar
'23 T-Bucket Pickup
Last wiki edit: Troubleshooting ignition Last photo:
Wiki Edits: 3
X3 . Depending on your performance goals and usage, the recommendations on your engine build would vary greatly. There are loads of guys on here (BTW, I am not one of them) who can get you pointed in the right direction on what heads, cam, pistons, intake and carburetor to use.
New Guy, First Engine Build ChrisInTexas Hotrodding Basics 4 03-19-2011 05:41 PM
engine build roadhogg Engine 3 09-06-2009 05:29 PM
engine build roadhogg Engine 1 08-30-2009 01:27 PM
Help With 406 Engine Build Olds86 Engine 22 09-04-2008 07:02 PM
BBC engine build ??????????? Mook727 Engine 2 08-23-2007 02:10 PM
