what engines have the distributor in front - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2005, 09:16 AM
Back n the Game,Fully Hydrated
hey i was juist wondering what engines have the distributor in front? lol where it should be.
the 302 ford i know.
Old 08-17-2005, 09:28 AM
StevenC's Avatar
351,360,390, etc.. Mopar engines also have it in the front cocked to the side.
Old 08-17-2005, 09:47 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Buick V-8's
All fords do.
good ones
Old 08-17-2005, 09:54 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
GM'S LT1 and LT4 has them in the front, then all newer V8 have DIS systems.
Steve
Old 08-17-2005, 10:06 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Originally Posted by johnsongrass1
Buick V-8's
...........and V-6's
Old 08-17-2005, 10:22 AM
I think most Cadillac's and AMC's have them too.
Old 08-17-2005, 10:39 AM
Not al Fords are in the front. 55,6,7 Yblocks are in the front and have rear sumps with rink-a-dink external oilpump. Maybe they had some spys over at Chevy during the development of the early SBC??!!
Trees
Old 08-17-2005, 10:52 AM
T-bucket23's Avatar
Wiki Edits: 26
Engines
Good ones that were installed backwards
Old 08-17-2005, 12:04 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
only the bigblock mopars have them in front, the small block motors have them in back.
K
Old 08-17-2005, 01:07 PM
[QUOTE=1931 steve]GM'S LT1 and LT4 has them in the front, then all newer V8 have DIS systems.
once again....GM steals ford engineering....flatty's had 'em in the front
Old 08-17-2005, 01:26 PM
aka Duke of URL
Trees
...hunh?
FORD and LINCOLN Y-BLOCKS have rear driven distributors. What was wrong with the external oil pump? You enjoying jacking up engines to change a pump?
And as for corporate spying, I think you will find it was the other way around. The FORD and LINC Y-BLOCK were here before the SBC.
Old 08-17-2005, 01:36 PM
Originally Posted by KULTULZ
...hunh?
don't ya love it when they jack with the Ford guys
Old 08-17-2005, 03:03 PM
Malibu73's Avatar
'68 Chevelle Malibu Sedan
FOrd 460's have it in front.
Old 08-17-2005, 03:34 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
[where it should be.
Where it should be??????
Id say a ton of Chevy guys as well as Willys and Centerline with there old Hemi's might disagree about were they should be. If meaning to be good in yer book that is?? HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Idler Arm help after front tire change 360Camaro Suspension - Brakes - Steering 1 12-28-2003 11:49 AM
What Front Shocks for a Softer Ride? Doc68 Suspension - Brakes - Steering 3 12-03-2003 07:39 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
front clip retrofit beetle9 Suspension - Brakes - Steering 1 01-09-2002 02:24 PM
