We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
Closed Thread
  #31
Old 01-22-2005, 08:48 AM
Bowtiebuilder's Avatar
Bowtiebuilder Bowtiebuilder is offline
friends dont let friends drive
Line Lock
Where can i buy an electirc seloind to make a line lock on my El Camino
Old 01-22-2005, 10:29 AM
babe_n_indy babe_n_indy is offline
Location: Justice, Illinois (bred, born and raised in Louisville, Kentucky)
Jegs or Summit have the solenoids for you. They have line lock solenoids. They have the whole works!
Here's one link for Jegs:
http://www.jegs.com/cgi-bin/ncommer...&cgrfnbr=148603
And, here is a link for Summit:
http://store.summitracing.com/defau...h&Ntt=Line+Lock
Hope this helps.
Old 01-22-2005, 12:45 PM
What excactly is a line lock?
Thanks that helps alot pretty soon ill be roasting my tires till they pop
Old 01-22-2005, 02:31 PM
just another car guy's Avatar
just another car guy just another car guy is offline
Originally posted by Nightfire
Just what I was thinking......front wheel drive or four wheel drive? Either way it makes no sense.
Mike
I saw that too, no such animal
Old 01-22-2005, 03:06 PM
bracketeer's Avatar
bracketeer bracketeer is offline
489 Lemans
line lock
Line lock is not used to launch the car. It is so you can do a brake stand without hurting the rear brakes. A tranny brake is used for launching the car. Line lock will not release as fast as you can foot brake the car. It will actually reduce your ET on the track.
Old 01-22-2005, 03:37 PM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstar
Wiki editor
Last wiki edit: How to identify a Ford V8
Wiki Edits: 713
I take that to mean that I lied about building a FWD 1970 Chevelle?
At the Bonneville Salt Flats... 130mph is known as First gear ...............
Old 01-22-2005, 03:59 PM
I guess I didn't pay good enough attention enough to the post, i thought someone was saying they had one stock
Old 03-15-2005, 12:27 PM
Mr Ed's Avatar
Mr Ed Mr Ed is offline
Just thought i'd mention that we often put the line lock on the brake line from the mastercylinder heading to the rear brakes thus when you push the button in (and hold it in) whilst not depressing the brake pedal; the solenoid closes off the pipe to the rear brakes, so when you do depress the brake pedal no fluid goes to the rear brakes and thus you can accelerate and smoke the tyres, this is good for showing off and also for racing when you want to heat the rear tyres (burnout) but not wear out the rear brakes, it also means that you can drive forward slowly using your footbrake whilst smoking the tyres. When staging for a race i just use the footbrake for the launch control which clamps all the wheels as you load up the engine; when using the line lock as a launch control for racing it is too easy to start to rotate the rear tyres if the front brakes are locked and you accelerate a bit too hard, and also you can push your front wheels through the start beam and red light, so a trans brake is a better option.However some people use the line lock as a launch control and have good results.My solenoid is a Summit and i installed it backwards on the rear brake pipe; this is quite common amongst a lot of rodders i know.
Old 03-16-2005, 12:36 AM
Bandit1980's Avatar
Bandit1980 Bandit1980 is offline
I'm happy one people talk about it. Why don't put line lock on the rear brake I think it's the better way to have the best control. Expecialy for slowly go forward and still burns the tire Just don't know why nobody talk about locking the rear line when talking about line lock.
Old 03-16-2005, 06:03 AM
redsdad redsdad is offline
Will I ever get it done?
Line Lock
When they first came out, manual trans cars were the thing to drag race. Three pedals, two feet. You do the math. If the track was not perfectly flat or if the clutch had any drag at all, you would roll out of the beam and red light. A "line lock" locked you on the line (also sometimes called a "Roll Control"). With one, you could have your left foot on the clutch and your right foot could have the engine in the trees and you didn't have to worry much about an accidental red eye. Some drivers realized additional benefits. You could lightly pre-load the clutch to take some of the slack out of the drive train to prevent breakage. I remember reading that Bob Glidden used a pressure gauge on the front brake line so he could pre-set the pressure at a known value which would prevent the car from rolling but would allow rolling as the clutch engaged so he could control the roll into the beams for staging deep or shallow. As the performance abilities of automatics improved, and when tranny brakes appeared, the line lock was relegated to a burnout device for most people.
Closed Thread
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
