We're winning the case!
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
Closed Thread
  #1
Old 06-10-2004, 08:53 PM
frankenvette's Avatar
frankenvette frankenvette is offline
Go ahead kid squeeze the wheez
What exactly is a line lock?
O.K., what is a line lock, what does it do, and how is it used?
Old 06-10-2004, 08:55 PM
poncho62's Avatar
poncho62 poncho62 is online now
poncho62's barnstar
Wiki editor
Wiki Edits: 5
Line lock is a solenoid that actually locks the front brakes, so that you can do a brake stand and warm up the rear tires. As long as you hold the little button, the front brakes will stay on.
It's also used to prevent the car from taking off of the starting line too soon and can be used as a hill brake.
Old 06-10-2004, 08:57 PM
So you hold the button in to set the brakes, when you release the button, you release the brakes, that's it? Seems easy enough!
Old 06-10-2004, 09:29 PM
Crosley's Avatar
Crosley Crosley is offline
Crosley's barnstar
Wiki editor
Last wiki edit: How to identify a Ford V8
Wiki Edits: 713
Odd,
I used a line lock on the rear brakes of my 1970 Chevelle. But then it was a FWD car
At the Bonneville Salt Flats... 130mph is known as First gear ...............
Old 06-11-2004, 05:43 AM
poncho62's Avatar
poncho62's barnstar
Wiki editor
Wiki Edits: 5
Originally posted by Crosley
Odd,
Sure you didn't have it in reverse?
Old 06-11-2004, 05:58 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
You stage, lock the brakes with your pedal, press the button which activates a solenoid which prevents the hydraulic fluid from returning from your front brakes. Release the brake pedal and hold the button down. You can then preload the clutch/transmission (if a standard). The button is released at the appropriate time you launch the vehicle.
Vince
Old 06-11-2004, 07:09 AM
302/Z28, makes a bunch of sense, thank you!
Old 08-28-2004, 07:11 PM
crayonbrown crayonbrown is offline
line lock
I had a line lock hanging on the wall for awhile , thought what the hell ill put it my Nova. Ok here is the prob, i have no instructions so i thought how hard can it be inline out line . After hooking it up i get in push the brake down and the front brakes are locked you say it works not so now to unlock it i need to push the button , its unlocks the car takes off and i step on the brake to stop and it locks back, so now i need to push the button again to go . Whats up with this i tried turning it around and hooking the lines the other way and it dons't work at all. Any help here . Also i tried to change the wires neg pos still works the same. Thanks
Old 08-28-2004, 07:21 PM
crayonbrown, take a look at this link:
http://www.hotrod.com/howto/49619/
Old 08-29-2004, 04:26 AM
line lock
Thanks .it would seam that there is something wrong with my LC because with no 12 volt hooked to it its locked . Its time to buy a new one or forget the idea of having one. thanks for the info jsdailey
Old 09-01-2004, 09:41 PM
53LEDSLED's Avatar
53LEDSLED 53LEDSLED is offline
here to learn
i dont know if this would work or not but would it work the same if you had one of those proportioning valves on your brakes and just have all the fluid go to the front??? or would that cause problems
Old 09-02-2004, 05:30 AM
Ed ke6bnl Ed ke6bnl is offline
Re: line lock
I have never installed one but would be curious if the line like valve is directional and the the pressure is holding it closed maybe the ins and outs need reversing worth a try. Ed ke6bnl
Old 09-03-2004, 08:32 PM
Nightfire's Avatar
Nightfire Nightfire is offline
Young & Idealistic
Nightfire's barnstar
Wiki editor
Wiki Edits: 4
Originally posted by Canadian Charlie
1970 Chevelle FWD?
Just what I was thinking......front wheel drive or four wheel drive? Either way it makes no sense.
Mike
Old 09-04-2004, 06:51 PM
Kustomizer's Avatar
Kustomizer Kustomizer is offline
'Stock' is just wrong!
Uuuh, got it backwards
Line locks kind-of do the opposite to what everyone has said...
You use your brakes like normal at all times. But, when you want to do a launch and keep from rolling, with your foot already PRESSING the brakes, you hold the line-lock button. This locks the pressurized fluid (from your foot-pressure) already holding the calipers into your rotors from returning to your master cylinder. Then, when you release the push-button (which is supplying 12V to the solenoid that is CLOSED (hydraulically), the solenoid allows the pressurized hydraulic fluid to return from your calipers to your master cylinder.
-Kustomizer
Closed Thread
Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
