what is exactly magna flux? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2006, 11:26 AM
i have heard this word alot when people are rebuilding engines, what is it? i know you do something to block,crank ,rods.
Old 07-02-2006, 11:46 AM
kain13's Avatar
they put some kind of powder on the block and run an electric current through the block to show any cracks? guys please correct me if im wrong
Old 07-02-2006, 11:47 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
K.I.S.S.
Passing a magnetic field through the part and sprinkling a fine iron dust on the part which will stick to any crack (and not to the rest of the part).
There are different techniques for doing this such as a big horseshoe magnet or even a large electromagnet.
There are also methods that use an ultraviolet dye or even a spray can chemical dye to detect crack.
Old 07-02-2006, 12:15 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Originally Posted by xntrik
K.I.S.S.
That is called dye penetrant test..it uses a dye and a black lite to show any cracks of defects..
Do a google for non-destructive materials testing and one will come up with alot of info..
Sam
Old 07-02-2006, 12:51 PM
does it make the metal stroger or just fixes the cracks
Marcel
Last journal entry: Choo-choo town
Magnifluxing
I was under the influence that the mag field didn't flow through the crack, there for making what looked like a line where the crack was. When the mag field was removed, the powder will fall off. It also helps if the idem has been cleaned.
Old 07-02-2006, 01:09 PM
kain13's Avatar
it is just to spot the cracks ps i was close
Old 07-02-2006, 01:14 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
It doesnt fix anything. As OneMoreTime said, it's one of many non desttructive tests you can use to tell you the condition of the part you're wanting to use.
Old 07-02-2006, 01:24 PM
NAIRB's Avatar
Magnaflux particle inspection is a very simple process. It is used on ferrous (magnetic) parts to find cracks and flaws. It does nothing to repair the part, but only to find cracks and fractures in iron and steel parts.
The part that is being magnafluxed is magnetized temporarily and then iron powder is either sprayed onto the part or it is washed onto the part in a special solvent.
Many cylinder heads are inspected with a simple permanent type magnet and a small dry powder sprayer. The iron powder aligns itself along any cracks and makes them readily visible.
Larger parts like blocks or cranks are normally placed in a magnaflux cabinet, and magnetized by a large electro-magnet. A solution of solvent that contains iron particles that will glow under a black light are washed on the part, the booth has a curtain, and even the smallest of cracks can be found by a skilled inspector.
Aluminum and other non-ferrous parts are inspected via xyglow inspection or dye penetrant. They can also be pressure checked.
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 09:00 PM
Question about coverting flux welder to gas workingclass Garage - Tools 5 04-03-2006 10:05 AM
Magna Chargers ??? 1Fine69 Hotrodding Basics 1 12-26-2005 06:26 PM
Strength of a flux core weld? Dejavu Body - Exterior 4 02-09-2005 01:09 PM
Suggestions on the best flux core wire? 357ford Body - Exterior 3 06-08-2004 11:23 AM
