What exactly is my chevy engine? Have casting and engine codes - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2006, 12:54 AM
optV's Avatar
Noob question: What exactly is my chevy engine?
Casting code: 3970010 (searching the charts suggest it could be a 302, 327 or 350)
engine code: v0808TBB (does the suffix prove that it is a 350?)
Thanks -Dan
Old 05-04-2006, 01:24 AM
James Stepp's Avatar
Your engine appears to be a 350,built August 8th 1970 at the Flint Michigan plant,4 bolt mains,was in a 1/2 or 3/4 ton with a 3 speed tranny.
http://www.nastyz28.com/spmenu.html This is where I found the info I gave you.
Speed
Old 05-04-2006, 01:30 AM
optV's Avatar
Thanks for the quick response. Is there any (negative) significance to the T (truck) part of the suffix? This engine is in my 1970 firebird that I'm planning on building up. Does it seem like a good start?
Old 05-04-2006, 04:12 AM
I'd say that should be a very good engine to build. If it's all original,you may find it to have a steel timing gear and heavy duty oil pump already. Not all the 4 bolt engines had 'em,but a lot did. As you've probably heard,you can get tons of performance stuff for the 350,and they're tough as a steel ball,so you're pretty well set.
Or,if you'd like something a little different,I have a very good 1968 Pontiac 400 4bbl. in my '57 GMC I'm planning to swap out,so it'll be available soon. I'd trade it for a good GMC 270 or 302 straight six.
Speed
Old 05-04-2006, 09:40 AM
rs67ss's Avatar
Check out www.mortec.com numbers galore, big block and small block. Blocks, heads. Good info.
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 04:05 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
engine casting numbers 62chevystepside Engine 3 02-20-2006 12:11 PM
chevy engine id DS1784 Engine 5 04-20-2005 08:22 AM
