What Filler do you Recommend for this Application>> - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2008, 06:46 PM
The spark plug wire tray is plastic. I'm re-routing my spark plug wires and want smooth the Plastic Plug Wire holding trays.
The channels are about half the diameter of an average spark plug wire.
Fillers I considered: 1st Apply Adhesion Promotor to the Plastic Trays..
- Two part plastic repair by SEM.
- Evercoat Kitty Hair Fiberglass Resin
- Extreme Rage Gold Filler
Should I apply an epoxy primer first? Second?
Help me out guys. I normally apply filler to bare metal and then Epoxy. I'm not too familiar with painting plastic trim pieces that will be exposed to some heat.
This is how they look now.
The look I'm trying to achieve with the trays filled and smoothed.
Old 10-13-2008, 07:23 PM
Last journal entry: More on the Cobra Engine
Not real shore of the correct name, but I would go to a Automotive Pait/Supply Store and ask what they use to repair plastic trim items like wings, sill plates and front covers.
Old 10-14-2008, 06:17 PM
Thanks yknot.
I'll check into it at the local shops.
Plastic filler tips. MARTINSR Body - Exterior 14 03-03-2009 05:11 PM
The most common mistakes made by the newbe working with plastic filler. MARTINSR Body - Exterior 7 02-14-2006 10:21 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
sandpaper... 38 special Body - Exterior 14 10-11-2005 04:30 PM
