What fluid level on 400 with 4deg. tilt - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2010, 03:17 PM
406 bug's Avatar
9.82 @ 139mph
Rather than installing a sbc on the standard 4degree tilt to the rear, (which puts the trans pan a 0 deg.) my motor is level which ends up tilting the trans pan at 4 deg. up to the rear. Question: what would be the correct fluid measurement on the trans. dip stick ??? Thanks in advance for your input.
Old 10-25-2010, 01:51 AM
SSedan64's Avatar
Fluid level should be at the Pan mounting surface with the engine running. You could try placing a angle finder on the Intake/Carb mounting surface & jacking the front of vehicle up to find 4*, then fill to full on the Dipstick. Fluid level will be higher when you lower vehicle. A little over full wont hurt.
turbo 400 with deep pan orangecrush Transmission - Rearend 8 12-15-2005 03:46 PM
TH350 Fluid Level 47willys Transmission - Rearend 6 11-03-2003 06:18 PM
turbo350 fluid level blowpop Transmission - Rearend 0 07-20-2003 07:13 AM
how low on fluid (TH350) before it quits moving? HotRodF100 Transmission - Rearend 4 10-11-2002 06:34 PM
B;owing trans fluid out the fill pipe Sandman Transmission - Rearend 5 06-05-2002 08:29 PM
