what ford engine fires this way?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2004, 10:50 PM
53fordguy's Avatar
Hellbilly Delux
Last journal entry: update after a long time
15486372 its out of a older ford dumptruck later 50's early 60's...
Old 12-31-2004, 11:33 PM
53fordguy,
This is the firing order for a 312 V8 Ford engine. It was used in many cars and trucks in the late fifties.
Scholman
Old 01-01-2005, 12:14 AM
comet boy's Avatar
When all else fails burn it
Last journal entry: more hiding stuff
There's a good site about Y-blocks www.y-blocksforever.com
Old 01-01-2005, 06:15 AM
willowbilly3's Avatar
Last journal entry: Body mods
Does it have those really cool ramhorn exhaust manifolds? It might be the larger truck verzion of the Y block, a 332 I think.
Old 01-01-2005, 11:13 AM
Max Keith's Avatar
firing order
That was also the firing order for the 292's as well.
Old 01-03-2005, 05:26 PM
53fordguy's Avatar
Hellbilly Delux
wow
it look alot bigger than a 312ci its a monster but it doesnt have ramhorn exaust... it has the usual wrap around exaust that leads from one manifold to the next and then out to the exaust
Old 01-03-2005, 09:27 PM
benwantland's Avatar
Ford's "Super Duty" name originally applied to the 401, 477 and 534 gas V8's used from the late 50's until the early 80's in heavy-duty applications. I believe they used the firing order you have listed. These engines are physically huge.
One way to ascertain the difference:
Y-blocks (such as the 312) had center valve cover bolts.
SD's had perimeter valve cover bolts.
Old 01-03-2005, 09:53 PM
53fordguy's Avatar
Hellbilly Delux
it has a huge holley 4bbl if that helps?
Old 01-03-2005, 10:22 PM
Lots of engines have huge holley 4v's, whether original or aftermarket. Check the valve covers.
Old 01-03-2005, 11:49 PM
redlightning's Avatar
Does it have two bolts in the center of the valve covers holding them on?
Old 01-04-2005, 12:45 PM
aka Duke of URL
Arrow
The 302/332 HD truck engine was in the LINCOLN Y-Block family. Discontinued in 1963.
