what is this FORD rear end called? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2012, 07:39 AM
Last journal entry: 27
we installed this ford car 9" rear when we built my 27 rod.
the fill plug was added by someone in this rears past.
what is this rear end called?
THANKS FELLAS!
Old 11-16-2012, 08:14 AM
Old 11-16-2012, 08:54 AM
delawarebill's Avatar
9" rear ???
i'm dense today.. i don't understand your question.. its a ford 9" and the bolted in front section is called a 3rd member.. also who ever welded that plug in.... did it way too high.
Old 11-16-2012, 10:21 AM
big gear head's Avatar
High Performance Rear Ends
Looks like a '57 Ford car 9 inch rear end with the WAR or WAB case.
Old 11-18-2012, 07:02 PM
Bye Jerks
It's just a FILL plug. The 9" has a level-hole in the 3rd member on the drivers side. So as long as there is room above the rear-end, it's fine.
Old 11-18-2012, 08:02 PM
Irelands child's Avatar
It's a 9-3/8 differential, not a 9"
Irelands child
Old 11-18-2012, 08:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I tend to agree that it's a 9". The 9-3/8" 3rd. member has (at least the ones I have seen) a downward curve to the topmost horizontal cast-in reinforcement rib. I once pulled one of these out of a hearse we had in our 'yard thinking it was a 9", spent the best part of a day digging a spider hole to work down under the damned thing (I was like 12 at the time). Finally got it out and hauled up to the shop. My Dad just shook his head.
The housing has two different ends on it: one earlier, one later.
Old 11-19-2012, 09:40 AM
It's a 9 inch, not the 9 3/8. I've got several of the 9 3/8 chunks and cobalt is right about the top rib turning down at the end. That is either the WAR or WAB case, which are the weakest of all the 9 inch cases. The '57 to '64 9 inch rear ends were not as strong as the '65 and later rear ends. The housings got stronger in '65 and the later cases had more material around the pinion pilot bearing.
Old 11-19-2012, 12:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Hey unclebill, would you mind if I used one of your photos in the Crankshaft Coalition wiki?
Old 11-19-2012, 05:48 PM
PLEASE DO.
maybe someone will find it useful.
Old 11-19-2012, 11:17 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by unclebill View Post
PLEASE DO.
Much appreciated.
1948 Ford stock engine/tranny with Ford 9" rear end beek15853 Transmission - Rearend 5 04-04-2012 08:56 PM
Welding a rear brace on a ford 9 inch rear end makaveli200369 Transmission - Rearend 4 07-02-2009 11:19 AM
Ford Rear End Kenrods Transmission - Rearend 9 01-01-2007 08:53 AM
S 10 rear end in a 33 Ford? jerry hildebrand Transmission - Rearend 1 12-13-2006 10:39 AM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 04:28 AM
