-   -   what front springs to use (http://www.hotrodders.com/forum/what-front-springs-use-101688.html)
proge 11-03-2006 03:48 PM
I have a 56 chev car with a modified 350.I have the old style traction bars on the rear, which I want to keep.The question is the front springs are probably the original 6 cylinder springs.They have the old style twist in spring spacers to level it out.I want to replace the front springs with something for better weight transfer an maybe ride better.Should I just get v-8 springs for the 56 or does someone else have a better idea.I dont know if a 350 is much heavier than a 283. Give me some ideas. thanks proge
techinspector1 11-03-2006 04:55 PM
The motors are about the same weight. Just buy some new '56 V8 springs and you're in business. Lots of places will have them, but if you have any trouble, these guys are the pros......www.eatonsprings.com
Be sure to inspect control arm bushings, ball joints, tie rod ends, etc. while you have it down. :)
Oh, and by the way, 56's came with 265's, not 283's. :)
pasadenahotrod 11-03-2006 05:39 PM
The springs are available at your local CarQuest or O-Reilly's parts store. They can order them and have them in just a day or two. Cost, probably about $60 the pair.
proge 11-03-2006 05:53 PM
I have heard that all fullsize chev front springs through 1971 will fit. Does anybody know if this is true thanks proge
Bryan59EC 11-03-2006 06:32 PM
They may all physically fit, but, I know for a fact that my 59 had at least four different sets of springs available for it.
These all different rates--wire diameter--number of coils.
If 55-71 will install in the pockets---that gives you a great variety of choices.
Personally, I would use the 56 v-8 coil for a convertable.
This might give a slightly lower ride height(maybe not), and would support the SBC. Quite possible have a stiffer rate for a firmer ride in the lighter HT/Sed cars.
Just a thought
Bryan
poncho62 11-03-2006 06:48 PM
Go with the V8 56 springs.......By the way the 56 Chevy six weighs more than the v8
techinspector1 11-03-2006 07:50 PM
Ha ha ha, well slap my bottom, you're never too old to learn are you? :thumbup:
BillyShope 11-04-2006 04:59 AM
This might be the time to consider adjustable coilovers, particularly if you think you might be taking an occasional trip down the quarter mile. With adjustable coilovers, you can go to different spring rates, left-to-right, and equalize rear tire loading on launch. See Page 7 on my blog:
http://home.earthlink.net/~whshope
proge 11-04-2006 02:51 PM
I dont know anything about adjustable coilover,What do you have to do to install them. thanks phik
BillyShope 11-04-2006 04:44 PM
Coilovers are not a "bolt on" for a '56 Chevy. Heidt uses Aldan coilovers on his custom units. In other words, it's going to take some fabrication work. Don't know if Heidt would be willing to work with you, but Aldan should be cooperative. There must be someone who posts here who's done up a tri-five with coilovers.
Incidentally, I've redone that page on my blog (dealing with front spring rates) and it's now much more user friendly.
proge 11-05-2006 01:56 PM
[QUOTE=BillyShope]Coilovers are not a "bolt on" for a '56 Chevy. Heidt uses Aldan coilovers on his custom units. In other words, it's going to take some fabrication work. Don't know if Heidt would be willing to work with you, but Aldan should be cooperative. There must be someone who posts here who's done up a tri-five with coilovers.
proge 11-05-2006 02:00 PM
[QUOTE=proge]
I think I will just get some new front springs and some adjustable shocks.I will probably have to wait till next year to try on the track. thanks proge
