What fuel pressure are you running in your Holleys? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2011, 07:42 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
I'm having issues with two different cars, both have the same 350 SBC with holley 1850 carbs, both have the stock chevy no return fuel pump.
do this pumps make too much pressure for the holley carbs?
what pressure do this carbs like?
edelbrock performer RPM goodies on both engines.
Old 04-26-2011, 07:55 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Holley recommends 5-7 psi at idle, and a minimum 4 psi at engine redline.
Old 04-26-2011, 08:14 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
I run a return pressure regulator and hold 5.5 psi across all RPM
Best $75 I ever spent.
Old 04-26-2011, 08:39 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
NAPA
Part Number 40987
Description Fuel Pump (OE Mechanical Type)
Attribute Pressure Rating:7 1/2 - 9 PSI,Gallons Per Hour:40 GPH @ 1800 RPM,Fitting Type(s):Inlet - Tube, Outlet - UNF - 2B Inverted Flare Threaded Fitting,Fitting Size(s):Inlet - 3/8", Outlet - 5/8 - 18 UNF - 2B
Comment w/ 2 Line Pump
Most Holley 4-bbl's want to see a maximum of 8 PSI, so I'd say that a regulator would be a good idea with this pump.
Holley 12-803 (Includes mounting bracket. Guage sold seperately.)
Pressure range 4.5 to 9 PSI
According to the Instruction sheet it can be plumbed as a dead-head or fuel return to tank.
Dual ports allow for 2 fuel lines to carb, or mounting a guage.
Old 04-27-2011, 03:47 AM
FastOrange's Avatar
I use an intank TBI pump (13 PSI) Regulated down to 6PSI Across all RPM. Works great.
V8 w/ carburetor + eletric fuel, runs too rich. Do I need a fuel pressure regulator? 5_speed Engine 17 10-25-2009 02:51 PM
Quadrajet 4bbl/Edelbrock street fuel pump- too much fuel pressure? Bob Turner Engine 2 11-30-2008 12:50 AM
Can oil pressure gauge be used for fuel pressure? Arrowhead Engine 37 05-27-2008 04:35 PM
94 holleys grapro Engine 1 09-13-2007 08:41 PM
Painting my Holleys binder47 Engine 8 01-07-2007 01:36 AM
