what fuel should I use? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2013, 05:00 PM
Last journal entry: gus`s 40
I have a 383 sbc with two relief flat tops, piston to deck is .010 with 64cc aluminum heads and I think the head gasket is .045 the cam IDs 480 lift 230 duration@.050 292 advertised with 110 lsa. My question is if I need to run a higher octane fuel, around here 91 is the highest at the pump, I have been meeting with the tune a little and at cruise speed and lightly acceleration I can hear a knock but don't notice at wot
Old 08-19-2013, 06:30 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Figuring max 12 cc for valve reliefs, I come up with 9.9:1 c.r., fine for 91 pump gas.
What's your base and total timing, and when is it all in? Heavy/light car, gear ratio, etc.
Semper Fi
Old 08-19-2013, 06:40 PM
I guess I thought with two valve relief they were around 3 cc,the car weighs 2400 3.70 gear right now the total timing is 34 initial is 16 all in at 3300 I have been messing with the mechanical had it in by 2800 before
Old 08-20-2013, 05:53 AM
I slowed down the timing curve and put the heavy springs in and the black bushings and took a little out if it that's where I ended up with 34 total and seem s to be all in around 33-3400 rpm if I unhook the vacuum advance I can just barley hear it with it hooked up its quite a bit louder.
Old 08-20-2013, 06:14 AM
will any adjustable vacuum advance work in my msd? there web site doesnt give allot of info on that, and you think the 91 octane will be ok? there is not allot of places to get it around here but I will try other stations. Thanks
Mr. gasket micro elec. fuel pump enough fuel output for 400 skinny? stewartcannon Engine 12 07-18-2013 01:31 PM
Can an external electric fuel pump suck fuel through an in the tank fuel pump? v123 Engine 3 06-02-2013 02:42 PM
Fuel Stink - How to Vent Fuel Tank for Chevy 350 TPI Engine kbuhagiar Engine 5 08-18-2010 08:54 AM
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 02:04 AM
Fuel/firing Problems with Fuel Injected TPI engine 87 camaro z28 chevcamz28newbie Engine 10 06-13-2009 01:03 PM
