What gas to run? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2012, 09:48 AM
s10mannn's Avatar
What gas to run?
I have a 1988 355 sbc and i was wondering what gas i should run? i have a mildly built motor that will have new Hyper pistons putting me at 9.3-1 compression. im guessing i can run 89? new 650 edelbrock carb..
Old 05-14-2012, 12:24 PM
327NUT's Avatar
You can start off running 89 and it may work just fine.....but you may also have to adjust your timing to keep it out of detonation under load. Really hard to say w/o knowing your complete engine combo.
Old 05-14-2012, 12:29 PM
Handfull54's Avatar
Run the good stuff. I even run the good gas in my little Toyota 4 cylinder pick up truck. 315,267 miles and no problems. Your not spending that much more and your valves and pistons will thank you later.
Old 05-15-2012, 08:54 AM
s10mannn's Avatar
fully rebuilt motor 88 350 bored .30 over so now going to be 355 magnum 270h cam 470 intake 470 exhuast lift headmen headers new pistons performer rpm intake manifold thunder series evs carb 6al igntition
stroker that has to run pump gas yardman Engine 14 10-12-2011 02:04 PM
how to run 383 stroker on pump gas 383elky Engine 27 08-23-2011 02:21 PM
what gas will I have to run 454cutlass86 Hotrodding Basics 3 03-11-2009 04:05 AM
can 10.4:1cr run on pump gas? rreruption Engine 14 12-12-2007 02:18 PM
Can I run my 406 on pump gas 94% Sampson Hotrodding Basics 22 04-11-2004 08:50 PM
