what gauge battery wire
have have 69 gmc with a 350 and a red top optima
i was wondering what gauge wire i should use for the battery i didnt know if the better battery or any would need different gauge the battery will be under the hood |
I would use 2ga for under the hood. Bigger than stock but not crazy big. I have bought it at Oreilly's before by the foot.
| The Following User Says Thank You to gearheadslife For This Useful Post: | ||
fwinter01 (02-14-2013) | ||
I've had trouble with every Optima I've owned over the last 15 years (4). I'll never buy them or recommend them to anyone for any purpose.
As far as cables go, If I am upgrading or installing any cables going forward in any vehicle I truely care about I will be using welding cable. Preferably 1-0. It conducts better, it's much more flexible and far more resiliant to damage and heat. Whenever I terminate new cables I solder them with a torch and it's amazing how well the jacket on the cable holds up to direct flame without melting. It's a bit more money, but well spent IMO. |
I used 1/0 welding cable on my sedan, but my battery is in the back, not under the hood. I think 2 gauge would be fine, but bigger never hurts (for cables). I believe in over-kill - I crimp, solder, then cover with shrink tube.
Spend some time reading the tech section at MadElectrical.com. They have some really helpful diagrams and explanations about charging systems.
what ever size you use, make sure the ground strap is as big too.
12v- to block and to the body. no sense upgrading the +cable if your still using the light weight oem braided ground. |
Pat |
There is a tool if you are crimping a lot of them. Here: Heavy Duty Hammer Crimper
You can also use a 1/4" round steel rod and a vise - better than just smashing them with the vice - use the steel rod to focus the crimp. For large cast lugs, I usually drill a small hole in the end and use that to solder the connection. When I can, I use adhesive-lined shrink tube - makes the connection waterproof. I buy the clear shrink tube - when it's sealed up, you can clearly see the connection and the wire color. (like the connections on the right in the picture). |
Use welding cables. They work the best(by far). Go down to your local welding supply store and ask for welding leads. Then just buy the end terminals and the bolts. I like the quick disconnect switches like the ones below.(you can get these through jegs or any aftermarket parts place)
For those who want the ultimate in battery cables, there is marine grade cable - fine wire cable like welding cable, but tinned the full length for additional corrosion resistance. Be prepared to pay a bunch!
Finally, someone got it right. It's not the gauge of the cable, it's the number of strands in the cable. A fine wire cable will carry a current load better than a coarse wire cable.
| Tags |
| battery |
| Battery Isolator Wire size? | 67Elcamino | Electrical | 5 | 09-04-2011 11:17 AM |
| Battery Positive Wire Routing | PancakesandSausage | Electrical | 3 | 01-26-2011 09:47 PM |
| Battery/starter lead gauge for 347 | 67Mustang Al. | Electrical | 5 | 10-07-2010 05:02 PM |
| How do I wire my trunk mounted battery?? | Half Breed | Electrical | 33 | 01-29-2006 03:07 PM |
| Battery cable 4 gauge ok? | Marcus | Electrical | 11 | 03-22-2005 11:19 AM |
