Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 05-09-2008, 05:11 PM
SteveU SteveU is offline
What gauge metal for rocker panels?
The rocker panels on my daily driver 93 corolla are getting bad & though I have searched the internet haven't found a source for new ones. The local parts store carries 22 gauge steel panels that are something like 12x20", would these work to weld in if no replacements can be found? A buddy has a 125 cfm compressor & sand blaster and another has a welder so hopefully this can get fixed up before it gets much worse. What do you think & are there any special precautions to doing this?
Thanks,
Steve
Old 05-09-2008, 05:28 PM
ShadetreeBody ShadetreeBody is offline
re: What gauge metal for rocker panels?
22 gauge IMO is too thin to weld, i usually use 18
Old 05-09-2008, 06:07 PM
matt167 matt167 is offline
 matt167's barnstar
Wiki Edits: 19
JC Whitney sells universal rocker panals, they'll take some cutting and fitting but there your best bet... 20 ga is probably what the body is now. 22 ga might be a little thin.. I think the universal rockers are 20ga
Old 05-09-2008, 06:15 PM
Bee4Me's Avatar
Bee4Me Bee4Me is offline
It fills the hole inside me
22 is about standard on "newer" stock and can be welded with a "good" wire welder on likely the lowest setting but be aware of burn thru's. So back off with the gun to reduce the heat some. If it's galvanized metal or e-coat,that will have to be ground down to bare metal to weld. Also, Try using smaller wire than 0.30 as it will weld a little easer and not as "hot" so you may not burn thru as much. Might have to crank the speed up a touch as well to fill.
Old 05-09-2008, 10:40 PM
robs ss robs ss is offline
 robs ss's barnstar
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "What gauge metal for rocker panels?"
gas gauge trouble cutsupreme Electrical 4 01-25-2008 08:40 AM
question about ballast resistor and wire gauge redneckprofessor Electrical 25 06-09-2007 12:50 PM
Where to buy Sheet metal cab Body - Exterior 12 07-25-2006 06:38 PM
"Basics of Basics" Molding repair / metal finishing MARTINSR Body - Exterior 3 11-26-2005 08:00 PM
Stamping Aluminum Body Panels? porscheracer Body - Exterior 3 11-03-2002 01:56 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
