What gauges to buy? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2012, 10:37 AM
What gauges to buy?
Not brand I am going with autometer I need to know what to monitor? They are going in a 71 c10 weekend driver/cruiser with a bbc 468 I know for sure I want a tach but then should I monitor water temp,oil temp,oil pressure ect...Also from what I've read I should be looking at the electrical not mech. gauges right?..Thanks
Old 03-31-2012, 02:57 PM
Banned User
Well, i don't think there's anything wrong with mechanical--they may even be more accurate. But the way i look at it, you have to wire them for lights anyways, unless you only drive during the daytime. So, why not just go electrical all the way? i also believe they are easier to install than mechanical because you can route the wires anywhere you want. (You can probably tell i generally favor electrical over mechanical.)
As far as monitoring, if you can afford all those gauges then great. i would first and foremost want tach and water temp. Then oil pressure, i don't give a crap about oil temp, but pressure yes. i've drifted towards, and gotten comfortable with, voltmeters----probably because that's what the factory does, but maybe we need both---an ammeter AND voltmeter to see not only how much is staying in, but how much is going in.
i would also recommend adding a "dummy light" to each of the gauges----this way you can shut it off immediately at the first sign of a problem. Otherwise, you could be cruising for miles before you notice something wrong.
Gauges Help DrBee Electrical 4 12-05-2010 08:46 AM
Anyone know where to get these gauges? marks914 Interior 7 11-10-2008 06:34 PM
Gauges SBC-S-15 Electrical 1 04-11-2006 08:22 PM
gauges DONTANG Introduce Yourself 1 10-03-2004 09:57 PM
Please help ID these gauges... 49 T&C Interior 4 11-03-2003 08:14 AM
