what gear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2009, 03:30 PM
what gear?
If i run a 3.42 or 3.55 gear in my 12 bolt what rpm approx will I be turning going down the freeway at 70 and can I put these gears in a 12 bolt that has 2 series gears in it now
Old 02-19-2009, 08:36 PM
SSedan64's Avatar
About 3100rpm with 26" tall tire with 3.42 gear, 3200rpm with 3.55 gear.
You'll need to use the aftermarket thick gears of a ring gear spacer.
http://hotrodworks.net/hotrodmath/quarter.html
Need Help with 700r4 No 4th Gear Jackson63 Transmission - Rearend 7 04-20-2015 09:45 PM
How do I remove the timing chain on a 350? piniongear Engine 9 09-20-2010 09:39 PM
Need some help sorting out tranny ratios and rear end ratios firstgear Transmission - Rearend 3 11-06-2008 07:39 AM
TH350 Speedometer Gear Choices skeeveman Transmission - Rearend 8 02-02-2007 12:37 AM
Internal Reaction (Ring) Gear shattered in 700R4... indy_85stariones Transmission - Rearend 8 11-30-2006 05:31 PM
