Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What gear lube
Thread: What gear lube
Old 05-28-2004, 03:55 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Regular old chassis grease.
If you are still running the closed driveshaft, you will have to move the rear end back after removing the 'bell' cover at the front of the torque tube to get to the 'U' joint. Lot's of work. Be sure to support the car well when doing this.
