What Gear Lube For My Rebuild Muncie - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2006, 06:00 AM
What Gear Lube For My Rebuilt Muncie
Hey guys,
I am very excited I just got back my newly rebuilt M-20 transmission for my 69 Camaro and it looks great. Completely new internals, case bead blasted, the works. The trans looks brand new. I won't be installing it for a month or so until the weather warms up.
Here is my question. I have always used 80W-90 gear lube and have never had a problem. Do you guys have a suggestions that may be better? I have heard a fair amount about synthetics both pros and cons and a fair amount about the GM syncromesh lube which is a mix of both. Or should I just stick with good old 80W-90?
What do you guys think?
Jim
Old 03-22-2006, 07:42 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
I really so no reason why you can't just switch to the full synthetic lube and pretty much be done with it.
Almost everything tested with syn. fluids has been noted as running quieter, cooler, more efficiently, smoother, etc.
Old 03-22-2006, 08:38 AM
35chev/302gmc's Avatar
Royal purple
I would go with Royal Purple synthetic gear lube.
Muncie rebuild markiemyster Transmission - Rearend 9 02-19-2004 07:36 PM
4 speed muncie problems Gnewnom Transmission - Rearend 6 12-24-2003 04:59 PM
rebuild a muncie trans 383vette Transmission - Rearend 9 10-08-2003 02:45 AM
80/90 gear lube ok for sm-465 and non possi rear end? zachscc Transmission - Rearend 2 03-02-2003 05:06 AM
Speedo gear tooth count on a Muncie? zachscc Transmission - Rearend 3 01-23-2003 06:10 PM
