what gear ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2010, 03:41 PM
what gear ratio
just wanted to know what gear ratio does a 4.3 chevy el camino 85 have on the differential . im trying to put a posi in there but need to know the gear ratio so everything else works fine. help
Old 10-25-2010, 05:32 PM
SSedan64's Avatar
Best way to check is remove the Diff cover and count the Ring & Pinion gear teeth or check the numbers stamped on the Ring gear.
SPID sticker will have the codes but rear could've been changed.
Jack up one wheel, turn 2 revolutions & count Yoke revolutions is another way but, isn't exact.
Which gear ratio is best for my cam?? eatonde Engine 7 01-20-2009 05:36 PM
7 hours, 33 phone calls, &30 pages of Threads later... Rearend? Tranny? Need Guidance 68ChevelleFromHell Suspension - Brakes - Steering 19 01-13-2006 01:01 PM
tire size and gear ratio inquiring_mind2 Transmission - Rearend 12 08-17-2005 09:57 AM
What Gear Ratio 79 Malibu327 Engine 5 04-12-2004 11:30 PM
What gear ratio should I use Maverick Transmission - Rearend 1 06-25-2002 08:40 PM
