what gears do i have?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2011, 09:04 PM
i pulled the cover and counted the pinion teeth and turned up 15 and the ring was 41 what i got please
Old 05-04-2011, 09:11 PM
2.73's by my calculations.
Old 05-04-2011, 09:42 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
in the future you can read this article in the wiki: clik here ... for guidance with gear ratio stuff
Old 05-04-2011, 09:57 PM
the rear end came out of a 1/2 ton truck does that sound right ?? i am putting it in a 82 c10 with a 454
Old 05-04-2011, 10:03 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
you counted them
the math doesn't lie
Old 05-04-2011, 10:46 PM
Wiki Edits: 31
late 70's early 80's during the govt push for economy and smog control, Chevy did some weird things to cars and trucks.. Among this was the high gear ratios, as 4spd over drive automatics were not around then, and the high gear ratios dropped the cruise RPM.. re count them tho. 3.08's were pretty common in 2wd's, but that would be 37/12. 2.73's were built tho
Old 05-04-2011, 11:04 PM
i checked and had my dad count them also it was 15 and 41 aslong as i make around 600lbs torque with my motor and use my t350 i should be fine right? were or what brand is a good cluster so i can make it posi trac
Old 05-04-2011, 11:57 PM
Wiki Edits: 31
600 ft/lbs out of a big block behind a TH-350 will equal broken parts.. at least stock or anything that is of unknown condition
If your going to change the center section to a positraction ( Eaton BTW ) why not change the gear ratio? a 3.42 would pull pretty good
RV cam or gears Mertz Engine 15 12-28-2010 08:48 AM
swapping 2.56 gears to 3.50 gears shmiv Transmission - Rearend 9 05-16-2009 09:18 PM
Tranny gears or rear gears? strummin67 Transmission - Rearend 4 06-12-2006 10:17 AM
4.11 gears??? 71gtx Transmission - Rearend 10 09-11-2003 10:59 AM
****ing gears bak9jo Transmission - Rearend 0 07-28-2003 10:22 AM
