-   -   What Gears To Get? (http://www.hotrodders.com/forum/what-gears-get-231035.html)
Cody82892 03-22-2013 03:11 AM
What Gears To Get?
I have a 1968 Chevelle with a 383 Stroker motor I am puting in it. It has a 5, 18 lift cam, a set up heads with 76cc to drop the compression from 11:1 to 10:1. A 1500 RPM High-Rise Airgap intake. I have a TH350 Tranny with a 3,500 Stall. But I have a stock rearend. I am interested in puting in a Positraction rear end. But I am uncertain of what gears to have. The car is mainly used for in-town and highway driving. Off the top of my head, I believe I have 15 in rims, and 245 tires. I was thinking 3.73 gears, because I heard it is a good middle for both performance on highways as well as accelerating from 0.
33Willys77 03-22-2013 06:14 AM
Here is a place that has many calculators to figure what you want.
Currie Enterprises Calculators
AutoGear 03-22-2013 06:55 AM
Off the cuff I would say 3.55 or 3.73:1s and lean towards the 3.55s personally. You'll want to find out what your camshaft's cruising RPM is and work that into the equation.
Sounds like a solid car!
