what gears for the maverick - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2009, 10:35 PM
72 grabber 51F-1 65 chevystang
I am building my maverick into a drag car. It will have a 10.5-1 347 .550 lift cam, rhs 215cc heads, victor jr and 780 holley. It will have a c4 with a 3500 stall. It will be a 9 inch rear. I am planning on going with 4.88 or 5.13 gears. It will be an 1/8 mile only car. I am wanting to go threw the traps at roughly 7000 rpm on a 26 inch tall tire
Old 12-14-2009, 10:43 PM
ericnova72's Avatar
More for Less Racer
Without knowing how much power the engine makes(dyno) and how heavy the car is there is no way to nail this down closer than you already have. If you have a mph you intend to try to run through the traps at, then you can get a closer answer- 105 mph would need a 5.13, 111 mph would need a 4.88 based on your 7000 rpm target.
Lots of calculators here: www.wallaceracing.com
swapping 2.56 gears to 3.50 gears shmiv Transmission - Rearend 9 05-16-2009 10:18 PM
8.5 10 bolt spider gears Hubes Transmission - Rearend 1 07-02-2008 05:38 PM
Changing rear end gears? Cutlass403 Transmission - Rearend 8 10-05-2007 02:11 PM
What speedometer gears do I have? Johnny Bravo Transmission - Rearend 3 04-11-2007 10:19 PM
Exploded spider gears...? (12 bolt GM) Bumpstick Transmission - Rearend 7 10-07-2003 07:00 PM
