What gears and rearend in 1958 impala 4 door hardtop - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2012, 04:14 PM
does anyone know what gears and rear end came stock in this boat thank you
Old 04-01-2012, 06:36 PM
AZDoug's Avatar
Anything from 3.36 to 4.56, depending on what option was chosen. Could have been open or posi, also, on all gear selections.
Doug
Old 04-01-2012, 06:52 PM
Wiki Edits: 31
Only thing that can be certin is that it came with a drop out rear, which Chevy used from '58-'64... I think the 6's got the lower ratios and the 8's got higher ratio's but not 100% sure.
Old 04-01-2012, 07:34 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
348 with an auto trans would probably be a 3.08
348 with the manual trans commonly used a 3.36
3.36 was pretty common with all small block transmissions
4.11 was used in any car that came with overdrive
Old 04-02-2012, 03:36 AM
68 impala
it is a 1968 impala 4 door hardtop i miss spelled it and put 58 sorry guys but does anyone know about the 68
Old 04-03-2012, 05:06 AM
SSedan64's Avatar
68 came with 10 or 12-Bolt rears.
8.2" 10-Bolt, 28-Spline Axles, Casting # 3866166
8.875" 12-Bolt, 30-Spline Axles, Casting #3917879
Old 04-03-2012, 10:38 AM
thank you very much but how would i figure out what gear they have in there by those numbers i cant find anything on the internet. thank you again
Old 04-06-2012, 01:21 AM
SSedan64's Avatar
Those #s are the Housing casting Numbers.
There should be an Axle code on stamped on the passeger side Axle Tube.
Location Pic >> http://tech.oldsgmail.com/axle_useage.php
If the gears have been changed this wont help either.
If it's an Open Diff, jack up one wheel, rotate 2 revolutions & count the number of Driveshaft revolutions.
If it's a Posi Diff, jack up both wheels, rotate 1 rev, count DS revs.
3-3/4 turns = 3.73 etc......
1953Buick 2 door Hardtop moontanker Off-Topic 7 04-20-2009 01:26 PM
suicide doors on 64 impala hardtop alfredillo Body - Exterior 0 07-18-2007 06:57 PM
64 impala 4dr hardtop GCFDFirefighter Introduce Yourself 3 02-01-2007 04:36 PM
35 Plymouth 2 door hardtop interior happy hammer Interior 1 11-23-2006 09:54 PM
57 foor door hardtop ststock23 Body - Exterior 3 06-03-2003 03:19 PM
