What Glue to use on a padded dash? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2008, 09:14 AM
PapaG's Avatar
Ask me, Cause I don't know
Last journal entry: Kid Dean Car
I have a padded dash that is pulling up by the windshield. Can I glue it. I will remove the dash pad before working on it. I think the foam is still good and it is not cracked.
Thanks
Old 07-29-2008, 10:33 AM
DanTwoLakes's Avatar
Wiki Edits: 22
Take your dash pad off and find out how it is constructed underneath. You don't say what year or model your car is, but a lot of times it would just be simpler to replace the dash pad with a new one. This would be a good choice if the pad is very simple.
If the pad is in good shape, and you really want to take a shot at gluing it, you need to get the car out of that hot Texas sun and get it cooled off to a little above 70 degrees. Then you can use DAP Weldwood Top and Trim Adhesive. Use the spray grade which comes in bulk cans. I think the smallest bulk can is 1 gallon. You can brush it on or spray it. It will cost you around $25. 3M also makes a spray grade top and trim adhesive , but it is a lot more expensive than DAP. If you have an upholstery shop near you, you may be able to buy a pint or quart from them.
Keep the car inside for a day or two after you glue it.
Old 07-29-2008, 11:02 AM
more on dash fix
Your dash may be brittle and not want to lay back down. I usually clean it with a cleaner like 409 and then use a steamer while it is still wet and get it ply-able so it will lay down without cracking, then clamp it with clothespins and let it sit until dry then glue it down
Old 07-29-2008, 11:21 AM
PapaG's Avatar
Well it is actually a Chevy Luv Truck.
Old 07-29-2008, 12:19 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Like this one!!!! This is one I took 1st place with at the world of wheels in 95 (street machine class)
Old 07-29-2008, 02:51 PM
PapaG's Avatar
I do have a V8, but not a tilt front or bed. Looks like a nice truck.
Padded Dash Materials? scratchrod Interior 3 08-06-2007 07:15 AM
dash glue removal excaliberprime Interior 16 03-27-2007 10:01 PM
Padded Dash Repairs FinsForever Interior 3 01-17-2007 01:38 PM
Rhino Line padded Dash 76chevyc10 Interior 8 04-04-2004 03:51 PM
1957 chevy padded dash fisher57 General Rodding Tech 2 12-28-2003 07:37 PM
