What is this GM engine? GM 460776 on block - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2007, 01:13 PM
One of the heads has what appears to be a 376450 casting number. I just pulled this small block from my 1940 Ford street rod and am anxious to begin my first engine rebuild. I did a quick check and found 3.5" stroke and 3.75" bore that yields 309 cu. in., so I don't know if it's a 305 or 307 cu. in. engine.
The casting number on the block is GM 460776. Help please?
Old 09-29-2007, 01:23 PM
From the Mortec web site at:
http://www.mortec.com/castnum.htm
This is a 1978 or 79 305 with 2 bolt mains.
Old 09-29-2007, 10:11 PM
DoubleVision's Avatar
I don`t know if you meant to build another project or the 305. To be honest I wouldn`t waste my time on a 305 unless I was looking for economy. The 450 heads are pathetic wheezer heads that were used on the 262, 267, and 305 engines, they have real small 1.71 valves and not real good intake ports.
You can make a 305 run, but it will cost more, more than building a 350. If you stick with the 305, get some 416 or 601 casting heads, or better yet S/R torquer 305 heads.
Old 09-29-2007, 10:42 PM
just checked the milage on my 305 ...hauling some stuff lawnmower etc 11.4
Shane
Old 09-30-2007, 04:16 PM
DHMag's Avatar
FFR: 305s never came with 4 bolt mains from the factory.
Old 09-30-2007, 05:47 PM
Few Canadian trucks got 4 bolt 305s
Shane
Old 09-30-2007, 07:34 PM
DHMag's Avatar
Shane
depends on which online reference you choose to believe. personally, i have never seen a factory 4 bolt 305.
Old 09-30-2007, 08:24 PM
460778.....305...78-79...2 or 4, some Canadian assembled heavy duty truck blocks have 4-bolt main caps
Just going by what they say
Shane
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
small block engine rebuild 74camaro Engine 2 04-06-2006 06:08 PM
hello my name is justin and i have a question on identifing a engine block. Justin87 Engine 5 12-16-2005 12:15 PM
350 GM Goodwrench Caprice engine in 3rd Gen TBI F-Body? wrmason3 Engine 2 09-14-2002 08:01 PM
GM Engine Mounts johnnymopar Engine 5 08-29-2002 03:03 PM
