What is this GM part???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2009, 04:00 PM
woodz428's Avatar
Troll Hunter
I got a part about 10 years ago and I seem to recall at that time that it was for a Cadillac, but I may be wrong. I think, from other work, that it may be a power bench seat mechanism, but am not positive. It has a threaded portion that accepts a speedo cable size drive and it moves a mechanism that transfers motion to the 2 openings that appear like they might accept vacuum...but they don't. I only know that from disassembly and inspection of the internals. The # on it is 9837138 with what I assume is a date code...it is 2 9 7-72. Would think that it is a 1972 item, but again unsure. Any help would be appreciated. Thanks,Woodsy.
Name:	ebay stuff 005.jpg
Old 03-09-2009, 04:12 PM
poncho62's Avatar
Wiki Edits: 5
Speedo cable and vacuum?.....Sounds more to me that it may have something to do with cruise control..........
Old 03-09-2009, 05:19 PM
woodz428's Avatar
Troll Hunter
No...it LOOKS like a vacuum nipple. The 2 connections opposite each other have something( maybe a cable)that passes through and is driven within by the gear that is operated by a speedo cable size drive. There is no vacuum operation involved that I can tell, an inspection of the inside revealed a gear that is driven by the speedo cable size drive and then transfers motion to whatever comes through the other 2 passages. Not being a GM guy, it looks like some of the early power seat drives I have seen, that's why the "guess".It transmits motion as long as the drive rotates. I can't imagine how it would work in a cruise device...although years ago, when I got it, that was my first thoughts. It was only after opening the cover did I realize it was some sort of motion transfer device.....hence the power seat theory. Power window maybe?? Power antenna???
Old 03-09-2009, 05:20 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
Not found with that number on GM Parts Direct website, might just have to see the parts counter guy at a dealer.
I've never seen anything like it, got a pic of the other side?
Old 03-09-2009, 07:13 PM
Joe G's Avatar
According to this website:
http://www.oldbuickparts.com/nos/75parts.htm
It's a tailgate window regulator for a '71-75 Buick Estate Wagon.
Old 03-09-2009, 08:40 PM
woodz428's Avatar
Troll Hunter
That sounds like it, I didn't see if there was a pic but will go back to it and look. I thought it had sort of a window mechanism look. Probably fits most big GM wagons of the era, but not a Caddy . If I'd looked at this thread again before getting the backside pics I'd have saved some time. Thanks.
I'm attaching the back side pic, although it is moot at this point. Hey...I took 'em so here it is.
Name:	Back of GM whatzit 001.jpg
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Cheap GM HVAC blower motor fix. M&M CUSTOM Electrical 8 05-17-2009 11:10 AM
Where is GM part # for '59 corvette body? CHEV66JB Body - Exterior 0 05-14-2003 05:24 PM
