What is a good custom trans line setup - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2006, 09:36 PM
dpjmw's Avatar
I used a tubing cutter to cut my tranny lines when pulling my motor and tranny the other day. I could not get the lines loose from the car. I cut them about 10-12 inches from the tranny. I figured I would use a couple of couplings or something. BUT what about some of those quick disconnects or does anyone have a good idea for a cool custom setup?
P.S. Can I use hose to couple the lines that I cut - I had heard before that the pressure was too high? But thats what you do for a trans cooler?
Can anyone offer some advise? Thanks....
Old 06-06-2006, 10:02 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
a good quality hydraulic hose works well in the tranny cooler setup to splice or hook up something.
Pressure in the cooler system can run over 60 psi in a performance tranny at WOT / low vacuum situation.
AXOD Ford trans rebuild advice. 4 Jaw Chuck Transmission - Rearend 22 03-16-2004 06:37 PM
350 trans rebuild? jwart Transmission - Rearend 0 09-21-2003 09:06 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 02:23 PM
GOOD REAR END SETUP FOR A 68 CHEVY TRUCK erik350 Transmission - Rearend 1 05-14-2003 08:35 AM
Is this a good trans to buy Pro1972nova Transmission - Rearend 4 12-11-2002 08:05 PM
