What is a good glass cleaner - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2012, 07:14 AM
302 Z28's Avatar
None of the grocery store and auto parts store glass cleaners I have tried remove road film. All leave residue that can be seen when the sun shines directly on the glass. I have heard that Mothers now has a glass polish but I cannot get any information on it. I have also tried a home brew of ammonia, vinegar, alcohol and water with less than spectacular results.
Vince
Old 11-04-2012, 07:51 AM
RWENUTS's Avatar
Try just vinegar and water and use old newspapers instead of towels.
Old 11-04-2012, 07:56 AM
Last journal entry: was hoping for better than this
Old 11-04-2012, 08:24 AM
302 Z28's Avatar
OK, how good is the stuff?
Vince
Old 11-04-2012, 08:48 AM
Trucknut's Avatar
I've searched for years for a glass "CLEANER" that really works.
Old 11-04-2012, 09:54 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I use SPI wax and grease remover..the waterborne variety and tha tworks very well as a glass cleaner..
Sam
Old 11-04-2012, 12:08 PM
302 Z28's Avatar
Sam
Never thought of that wil have to give it a try.
Vince
Old 11-04-2012, 12:19 PM
life is a temporary assignment
I always have good results with windex and old newspapers instead of towels..
I find the newspaper is the key to a cleaner glass ..
Old 11-04-2012, 05:26 PM
302 Z28's Avatar
I tried that still streaks in direct sun.
Vince
Old 11-04-2012, 05:44 PM
Vince
I do find that somethings isn't made like it use to be.. Seems like everything is watered down a lot..
Did you try rainx ??
Old 11-04-2012, 05:51 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
X2 & randy would also agree, this works. Today however I needed a ice scraper with the freezing rain last night. Man them roads are slick as coon crap
Old 11-04-2012, 05:56 PM
Semper Gumby
Wiki Edits: 2
I go for the vinegar and water - about 3:1 water to vinegar solution.
Then wipe/rub with newspaper.
The pigments in the printers ink are excellent polishing agents, so I use the want ads as the wiper material - most ink per square inch!
(Sure makes my hands black, though!)
Old 11-04-2012, 07:04 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
My .02
Exterior glass:
First the glass has to be free of contaminants - if I'm not sure it gets a claybar treatment. The glass really has to be absolutely smooth to the touch, else do the claybar. It only takes a few moments.
Then clean with Stoner's Invisible Glass and wipe dry with a microfiber towel made for glass cleaning - most of these towels I've seen are green in color. There are similar products to Stoner's spray, just make sure if you have tinted windows that the product says it is safe for the tint (I've read several times that Windex is not safe for tint).
Then apply detail spray (I use Adam's) and wipe off with a microfiber towel.
Then a final polish with a clean dry microfiber towel. This is the step that gets any remaining streaks off the glass.
Microfiber towels tend to drag on clean windows, but the application of the detail spray in the third step lets the final polish in the fourth step go much easier.
Absolutely bright glass with no streaks. Do the same for interior windows except for the claybar step.
Old 11-05-2012, 05:19 AM
Last journal entry: 27
i am a professional window washer.
i use dawn dishwashing liquid , 0000 steel or brass wool and a top notch squeegee.
Old 11-05-2012, 05:34 AM
Irelands child's Avatar
The best I've used is what my least favorite rag, Consumer's Report suggested.
In a gallon jug;
2 cups denatured/rubbing alcohol
1/2 cup ammonia
1 to 2 teaspoons of Dawn
Fill with water
Newspapers as the rag
Works much better then Windex and any other that I tried, including several of the expensive auto parts stores "best"
Vinyl out-gas is terrible to clean off. Cigarette smoke is almost as bad - and both are bad for your health.
Never had to use steel wool
Irelands child
Fuel Injector Cleaner Canister Setups Any Good? fcastro Engine 2 07-21-2010 06:50 PM
Good Fuel System Cleaner for Motorcycles? Ayh127 Hotrodding Basics 9 05-11-2010 11:44 PM
Glass cleaner after wax and grease remover? wreckedGTI Body - Exterior 20 06-17-2007 05:21 PM
Rear glass defogger kits, are they any good? Ripped Electrical 2 01-23-2007 07:59 AM
Edelbrock's Triangle Air Cleaner: Good or Bad?? Oreif Engine 14 02-05-2006 09:21 AM
