Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What is a good street carb?
  #21 (permalink)
Old 10-28-2012, 05:34 PM
Dajerseyrat Dajerseyrat is offline
Originally Posted by techinspector1 View Post
Forget about less cam if that's what you have in mind. If your SCR truly is 11.00:1, then the cam that's in there now is perfectly matched to the SCR, providing a DCR of 8.53:1 with an intake closing point of 54 degrees after bottom dead center @0.050" tappet lift. Less cam will raise the DCR and render the motor inoperable on pump gas due to detonation. My best advice, build another, milder motor for cruising.
Can I cruise this motor with some carb and timing adjustment? Im ok with a slightly radical motor as I only go 5-10 miles to local car shows and not really looking to go stock..I guess I want to be able to drive this car to the track a few miles away and drive ti to local meets. Or do you think this motor is too ridiculously radical for that? I mean i have seen guys cruising big ***** blown big blocks to the meets..
