Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What is a good street carb?
  #53 (permalink)
Old 10-31-2012, 08:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Dajerseyrat View Post
FYI here is the distributor I have, and I cant find within the instructions how to set the timing curve.
Chevy Crab Cap Crank Trigger Distributor - 8489
That's a distributor used for racing so the distributor itself contains no mechanical or vacuum advance capabilities. If you want an ignition "curve", you will need an ignition box that is programmable. It's not unusual for the timing to be set to the max power setting and then an ignition timing retard is used to crank it up.
