Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What is a good street carb?
  #63 (permalink)
Old 11-01-2012, 02:01 PM
Dajerseyrat Dajerseyrat is offline
Originally Posted by cobalt327 View Post
That's a distributor used for racing so the distributor itself contains no mechanical or vacuum advance capabilities. If you want an ignition "curve", you will need an ignition box that is programmable. It's not unusual for the timing to be set to the max power setting and then an ignition timing retard is used to crank it up.
Ahh gotcha..Gonna swap that out then..
