Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What is a good street carb?
  #68 (permalink)
Old 11-02-2012, 08:13 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by Dajerseyrat View Post
Yes crank trigger up front, and MSD 2AL.
I was thinking of getting the MSD electronic distributer..Yay or nay?
Dose it have a vacuum advance function?
Thats what you need for a street car.
Vac advance for clean cruising at part throttle.
taming down the cam to something in the 240's dur on 112
solid street roller will really increase the drivability cruisability
it will still make a ton of power. but better idle more low end power
A simple roller cam swap. (Later)
Will a HEI distributor fit that chassis... (Firewall clearance)
