Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What is a good street carb?
  #100 (permalink)
Old 01-06-2013, 11:05 AM
Dajerseyrat Dajerseyrat is offline
Originally Posted by F-BIRD'88 View Post
If the compression ratio is 11.3:1 mix the 93 with some 110 unleaded. 50-50
If you can afford a car like that, you can afford to put the correct fuel in it.
Well the $$$$ is not the issue, I can afford to drop 100 octane which we have at a gas station 3 miles away, but the issue is when I cruise it to a show and may need to fill up somewhere else in a pinch..Would running 93 in a pinch when cruising home be a bad thing? I have a 15 gallon cell and am assuming the car would get about 5 mpg so it limits my distance I can go.
