Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - What is a good street carb?
  #118 (permalink)
Old 01-16-2013, 03:23 PM
Dajerseyrat Dajerseyrat is offline
Back to the discussion about the carb that is currently on there...I checked how open the throttle plates are, and they are exposing well over .040 of the transfer slots. Im guessing the car is currently ideling off the powervalve or the main circuit causing extremely rich idle. I understand the principle involved in tuning the idle but with the throttle blades open less the car wont even idle to check the vacuum and adjust the set screws...Which leads me back to adjusting the idle set screw which reopens the throttle blades well beyond .040 and back to the beginning I go...
So, I have read on several tech articles that some guys dril 1/16" holes in the the leading edge of the throttle blades to let more air in, and allowing them to close the throttle blades within spec.
How do you guys feel about this trick??
