What is a good street carb? - Page 13 - Hot Rod Forum : Hotrodders Bulletin Board
  #181 (permalink)
Old 07-18-2013, 12:51 AM
F-BIRD'88's Avatar
Yada Yada Yada
PM sent.........
  #182 (permalink)
Old 07-18-2013, 02:30 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Harold Brookshire (662) 562-4933
Email: brookshire@panola.com
PM at speedtalk
  #183 (permalink)
Old 07-20-2013, 04:57 PM
Definitely looking into this over the winter. I can tell you one thing, this motor makes some power...My Centerforce clutch is slipping in 3rd gear at 5000 rpms...Anyone have any recommendations for a nice streetable twin disc or something that will handle 600-700hp???
  #184 (permalink)
Old 07-20-2013, 05:11 PM
vinniekq2's Avatar
an 11 inch single disc should hold your 600 HP .tires should break loose before the clutch slips
  #185 (permalink)
Old 07-20-2013, 05:23 PM
Then something is not right..I smelled the burning clutch and rpms climbed rapidly without the car moving faster. Can i be making that much TQ? They said this clutch was good for 550 TQ. Can the throwout bearing be releasing it just a bit?
And FWIW I may just deal with the drivability, cause when I open this motor up, OMG the sound!!!!
  #186 (permalink)
Old 07-20-2013, 05:30 PM
thinwhiteduke's Avatar
Living In The Past
Post a vid
Duke
  #187 (permalink)
Old 07-20-2013, 05:35 PM
vinniekq2's Avatar
550 torque and tire spin? the tires should break loose.
  #188 (permalink)
Old 07-20-2013, 05:41 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Clutches need to be broken in properly, just like brakes. And adjusted correctly. And no oil, etc. on the friction surfaces from the engine or tranny or even from over lubing the pilot.
  #189 (permalink)
Old 07-20-2013, 05:47 PM
I do have s light oil leak Im chasing down...Now that I think about it, oil could be blowing backwards and getting on it.. Im assuming this requires removing the clutch and cleaning the surface really good.
As far as break in, it said no hard launches for 500 miles. I havent launched the car as of yet. This was 3rd gear slippage.
  #190 (permalink)
Old 07-20-2013, 05:48 PM
Full Hoosier road racing slicks, 90* outside.
  #191 (permalink)
Old 07-20-2013, 05:49 PM
Originally Posted by thinwhiteduke View Post
Post a vid
Duke
Actually gonna pick up a GoPro just for this car..
  #192 (permalink)
Old 07-20-2013, 05:55 PM
vinniekq2's Avatar
cleaning oil from a friction surface usually involves brake cleans for the pressure plate and flywheel.and usually a garbage can for the disc.If it was a stock engine I would heat the disc with a torch,careful to avoid the springs.
you can try brakekleens and sandpaper, I wouldnt
  #193 (permalink)
Old 07-20-2013, 06:02 PM
Can Oil really get onto the surface from a leak by blowing backwards from the front of the engine?
  #194 (permalink)
Old 07-20-2013, 06:12 PM
vinniekq2's Avatar
Its your car,no one online can see it or hear it? If it slips then the clutch has a problem
  #195 (permalink)
Old 07-20-2013, 06:41 PM
Yeah, but If it is dry when I go under there what else could it be? Other than the clutch just not holding.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Good street racing motor SBC 350 Hotrodding Basics 5 10-10-2011 08:44 AM
Good Gear For The Street wormy5 Transmission - Rearend 10 01-26-2009 11:54 PM
Is all of this be Good for the street ? chevy350_Camd Engine 9 01-14-2008 09:36 PM
a good street cam 75jeep Engine 5 12-21-2004 07:51 PM
is this a good street engine? Mike_82 Engine 5 03-19-2004 09:31 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
