Less dyno time than a carb would require. And most dynos only allow you to set WOT fuel curves. The rest is done on the street by logging your data- which is much easier with EFI than a carb.
You'd also need a high pressure fuel pump, and either somesort of TBI unit or a new or modified intake to run multiport. |
https://www.youtube.com/watch?v=5nh7ETyG9JE
Video of idle. On a side not base don the previous conversation with the 11.3 compression and the timing locked out at 34 degrees would I be able to run 93 octane pump gas cruising around locally? |
Well the $$$$ is not the issue, I can afford to drop 100 octane which we have at a gas station 3 miles away, but the issue is when I cruise it to a show and may need to fill up somewhere else in a pinch..Would running 93 in a pinch when cruising home be a bad thing? I have a 15 gallon cell and am assuming the car would get about 5 mpg so it limits my distance I can go.
I actually dont know have'nt checked that yet. Pretty much still set up the way I got it. Im assuming it needs and adjustment by now. Would you go by the cam card recommendations? I normally keep my valves around 20-22 thou, cold..
different cams have different lash settings. It sounds like a loose lash cam.Im guessing 028 ish? by the sound. 93 octane will work and you should get 10 MPG at 65 ish in high gear
My engine made peak torque @ 4750 and peak HP @ 6500 there fore in my application the engine is fabulous(just my opinion) from 4,000-6800. You Cam is about the same as mine.You have a bigger intake and a little smaller engine.I would guess that from 4300-7800 would be a use able range,especially if you road RACED. I wouldnt spent a lot of time at 7800 with out shaft rockers,though Im sure your girdle system is just fine.The only thing I would even consider changing on your car would be a 5 speed. Your car is more race oriented than mine. probably makes as much or more power too.
I would have a couple chips for your ignition too. a 7500 RPM chip would keep that engine glued together with it bordering on too much power for daily use and not rain friendly. Have you driven the car hard yet? |
No...Scared of it actually..LOL Contemplating either selling the engine or tuning it down a bit for street use. I would be happy with 400-450hp. Im guessing this one is around 600-700 ish...
As far as the MSD chips, the MSD box I have does not use chips, it has adjustable dip switches. I have it set at a 7400 rpm limiter as of now What would be a fair price for this engine and tranny set up and you know of anyone interested? |
| Good street racing motor | SBC 350 | Hotrodding Basics | 5 | 10-10-2011 08:44 AM |
| Good Gear For The Street | wormy5 | Transmission - Rearend | 10 | 01-26-2009 11:54 PM |
| Is all of this be Good for the street ? | chevy350_Camd | Engine | 9 | 01-14-2008 09:36 PM |
| a good street cam | 75jeep | Engine | 5 | 12-21-2004 07:51 PM |
| is this a good street engine? | Mike_82 | Engine | 5 | 03-19-2004 09:31 PM |
