the 850 you have is probably the correct carb.The cam you have is not what everybody likes.I have a cam like that and use a bigger carb and it behaves fine.It takes awhile to learn how to tune it.
Please post your fuel pressure at the carb inlet.
You do not need a new carb and you cannot buy a magic carb that will run perfect out of the box.
You need to dial in the one you got ..The problem is more if a ignition set up problem than the carb. What cam? what Distributor Timing curve, base timing at idle?? what carb model number pri jets sec jets,,, power valve. What intake manifold? Auto trans? Converter stall speed? manual transmsision? Fill in the blanks. Can show you how to set it all up to run clean, not load up and not foul plugs. Its a matter of set up details not a i need a new carb problem. The carb is not too big. Last edited by F-BIRD'88; 10-28-2012 at 02:54 PM. |
Same guy back again looking for that magic carb.
You didn't take my advice last time. Your last radical motor needed a specific setup which explained to you in detail but you don;t ant to listen. This engine is going to be no different. When you set it up right it will run right and drive fine on the street. reread the last go around and do it this time. |
Fuel flow into the carburetor bowl is controlled by a needle and seat arrangement. Excessive fuel pressure will unload the needle and seat and blow raw fuel into the intake manifold, creating the problems you posted. Most of you younguns have grown up with EFI, where you can make more horsepower with more fuel pressure. Carburetors are a completely different ballgame. Get your fuel pressure down to 5 to 5 1/2 psi before you do anything else. |
Carb: Dillman Racing Carb plugs: NGK V power 7 R5671A-7 Ignition: MSD 6AL Coil:MSD Blaster 2 Cam: Lunati #50199LUN I have the reciepts for the engine and spoke to the engine builder. Was told it was a 383 punched out to a 389 and about 11.0:1 compression Rear gears are :308's Tranny is a Jerico 4 speed Does this help? |
The carbon in the carb and the carbon sparl plugs show its severly carboned up.
You gave no usefull info. The cam part number is the custom grind cam order number Tells you nothing. |
it looks like you have a race car bolted to your race carb and race engine.what are you trying to accomplish? are you racing it? curious how you like the jerico? I considered it but with out a speedo I went with a street friendly tko.
that carb is obviously a holley thats been modified |
| Good street racing motor | SBC 350 | Hotrodding Basics | 5 | 10-10-2011 08:44 AM |
| Good Gear For The Street | wormy5 | Transmission - Rearend | 10 | 01-26-2009 11:54 PM |
| Is all of this be Good for the street ? | chevy350_Camd | Engine | 9 | 01-14-2008 09:36 PM |
| a good street cam | 75jeep | Engine | 5 | 12-21-2004 07:51 PM |
| is this a good street engine? | Mike_82 | Engine | 5 | 03-19-2004 09:31 PM |
