What grade of steel for... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 02:15 AM
1tunda's Avatar
Hi,
I want to know what grade of steel I need to use to reinforce my truck frame.
I plan on welding together round steel tubing to stiffen the frame and Im not sure if there are certain alloys to use or to stay away from.
Thanks
tunda
Old 08-01-2006, 09:07 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
not a good idea to use galvanized cause the fums from the welding are not for human consumption. Other then that any cold rolled thin wall would be ok. Remember the reinforcement will come from the structure and is not necessary to use large gage steel tube for strength.
Old 08-02-2006, 12:28 AM
1tunda's Avatar
my local steel supplier said they only have 1-5/8" x 1/8" wall. Do you think 1/8" should be enough?
I want to make sure I do it right the first time.
Thanks for your reply.
tunda
Cowl Hood - Fiberglass vs Steel leejoy Body - Exterior 3 06-14-2006 09:20 PM
DIY - custom steel cowls, for a steel hood? Woogeroo Body - Exterior 1 12-18-2005 07:43 PM
Fasteners ... 18.8 Stainless or Grade 8 ? 66GMC Suspension - Brakes - Steering 3 09-27-2005 04:40 PM
Is if me or the steel? redsdad Body - Exterior 4 09-10-2005 08:21 PM
steel cowl hood scoop gonzodw Introduce Yourself 1 11-20-2004 10:20 AM
